DD 16 ac clutch
Discussion in 'Western Star Forum' started by Perchie15, Jul 25, 2023.
  1. Perchie15
    Perchie15 Light Load Member
    232
    70
    Aug 16, 2021
    2011 westernstar compressor not kicking in and ya I don’t have power to the clutch. I checked fuse in dash it’s good! Tried following wires but goes into a bunch!
  3. RocketyMan
    RocketyMan Medium Load Member
    549
    336
    Jun 5, 2015
    The binary switch needs to sense proper pressure in order to turn on the compressor. Need to have appropriate amount of refrigerant in the system.
    I would suggest taking it in to a dealer if you don't know how the HVAC system works nor the resources as you could potentially do more damage to the system.
  4. Perchie15
    232
    70
    Aug 16, 2021
    I never knew there was a binary switch I was looking all over for the stupid low switch. So even if they binary switch isn’t working I won’t ever get power to the clutch? Weird how that works then.
  5. RocketyMan
    549
    336
    Jun 5, 2015
    You need to actually verify you have the correct refrigerant in the system AND the correct amount. The stuff doesn't last nor keep forever.
  6. Perchie15
    232
    70
    Aug 16, 2021
    Forsure I do I put new stuff in it! 3.30 needs 3.30 thoufg and ran out before got to what it needed arghh
  7. Perchie15
    232
    70
    Aug 16, 2021
    Yeah but the thing is I don’t have power going to the compressor. And I don’t have correct amount of Freon so that won’t be an issue now. I’ve done it same way for long time now! Brand new Freon
  8. RocketyMan
    549
    336
    Jun 5, 2015
    I have no idea what you're trying to describe.
    You need to have the proper amount of refrigerant in order for the TX valve to activate the relay going to the HVAC compressor. The WHOLE SYSTEM needs to be evacuated and "3.30 lbs" (whatever the sticker says under the hood) filled. THEN the TX valve will [should] operate accordingly, thus, allowing the AC compressor request from the HVAC controller to operate the compressor.
    Get 3.30 lbs filled in the system, then continue troubleshooting.
    MOD: 70B, 703
  9. Perchie15
    232
    70
    Aug 16, 2021
    Year I have what the stickers says 3.30 but still no compressor engaging. I’m lost for diagnoses I changed the trinary switch still nothing. Argh
    Rideandrepair Thanks this.
  10. RocketyMan
    549
    336
    Jun 5, 2015
    Swapping out parts without actually verifying them isn't a good strategy on fixing the problem.
    It could also be the wiring, or the HVAC controller, PWR, GND, etc.
    AModelCat Thanks this.
  11. RocketyMan
    549
    336
    Jun 5, 2015
    What is the last 6 of your vin? I can look up wiring, since it doesn't sound like you thoroughly looked at that first.
