DD s60 11.1 Turbo help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jsnap, Sep 24, 2014.
  1. jsnap
    jsnap Light Load Member
    77
    7
    Apr 10, 2008
    ststen island NY
    [TABLE="width: 97%"]
    [TR]
    [TD="class: ftalternatingbaron, width: 99%, bgcolor: #F0EEED, align: right"][TABLE="width: 100%"]
    [TR]
    [TD="colspan: 2"]OK all here is my situation I have an 11.1 400 hp program that was bumped and made on the dyno years ago when i did it 563 at the wheels... That being said I swapped the stock turbo out with the BW 171702 and im thinking that this turbo is to big for the 11.1 because the exaust temp is to high I think. Say 1200 rpm cruising not pulling and not real heavy running 950 degrees.....Now I drop a gear come up to say 1600 rpms same condition same speed temp drops say 750 degrees.... So im thinking that turbo may be to big for the amount of air the 11.1 is moving .... Please what do you guys think... Is all good the way its is with the temps or is that BW turbo to big for the 11.1.... Thanks in advance[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
  3. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    rebel 127 I know could help
  5. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    563 at the wheels is quite impressive for a 11.1L. as far as egt's at 1200. 1200 is to low of a rpm for a 11.1L or even a 12.7 for that matter they really seem to like 1400-1800, i don't think i would cruse it at less than 1300
    magoo68 Thanks this.
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I agree with this.
  7. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    If your putting enough fuel into it to make 563 hp my guess is a smaller turbo will run hotter. I'd just run it higher rpm like ex and hh suggested to keep the airflow up to better match the fueling
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    rebel can tell you which turbo would best match your specific needs for what you have. p.m. him.
  9. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    I would bet the 171701 would be best.
  10. Bush chook
    Bush chook Light Load Member
    144
    43
    Apr 27, 2009
    Geelong
    they don,t make a bolt on turbo to suit 11 litre , you,ll have to make your own as most other people do , 92 series with a larger cold wheel works wonders for 400 plus hp
  11. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    thats what i was thinking
