DD S60 Valve cover tag
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Big_Red, Nov 14, 2021.
  1. Big_Red
    Big_Red Medium Load Member
    439
    989
    May 5, 2011
    Not active
    I’ve got a factory reman.14L Detroit. The valve cover tag says it’s an 02. I’m wondering about the parts listed in the tag and in what system the part is looked up. Basically how to read the tag.
    For example
    1870 turbocharger
    0766 valve mech
    0479 injector
    The valve mech came up on google for the jakes and I see what I guess are the overhead settings.
    Where do I go to see what turbo and injectors these numbers correspond with? Thanks
  3. Ross_Tech
    Ross_Tech Light Load Member
    133
    134
    Aug 31, 2021
    If I understand it correctly, you would have to have the parts catalog for that year. I've attached a page from the '95 parts catalog, (couldn't find '02). The numbers on your label are option numbers for your engine. i.e you have option 0479 for your injectors. The option number is listed as "types" on the right hand column of the page, and then it lists all the quantities of various part numbers that come with that option. Over on the left is their individual part numbers. It's much easier to use Parts Pro or Excelerator to look up the parts by engine serial number though.
    Big_Red Thanks this.
  4. Big_Red
    439
    989
    May 5, 2011
    Not active
    Thanks a lot. I’ve been tryin to learn all the ins and outs of my engine and hit a wall as far figuring out the OEM parts
