DD13 code Spn 6259 fmi 0, anyone have experience with this?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by feldsforever, Jan 6, 2022.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Does any one have experiance with this code. ? It a cascadia dd13.
    I don't want to miss anything. I was able to down load something that explains how to start at the p sensor. And test all the way down to the egr butterflies.
    So. I was derated 25%. With spn 411 fmi 13. It brought me to the p sensor. I took a day and learnt how to clean and Or replace whichever was nessacy. A simple five min cleaning and I was back on the road.( test driving the nox sensor replacement) about ten mins in I was derated again same code.
    I pull over and clean again. The first cleaning the engine was cold. The second cleaning I was at highway speed. I noticed when I removed the sensor. The front port was wet but the back port was not. So I cleaned it again. Looked at the dash and the new spn code is 2659. Fmi 0
    According to what I just read. It is either the sensor that moves the butterfly in the egr or the actual butterfly is jammed. Causeing a uneven return flow causing the soot to clog the p sensor.
    Any advice from some one who has done it woukd be great. Or any questions if I complacated my question.
    D.Tibbitt and 77fib77 Thank this.
  3. 86scotty
    86scotty Road Train Member
    4,807
    13,215
    Aug 27, 2017
    Appalachia
    Man, you're having a bad run of luck lately. I don't know what that is but hopefully you have some smooth sailing soon.
    InTooDeep, D.Tibbitt and feldsforever Thank this.
  4. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Thank you.
    It always comes in groups. When its good its great and when its not its not. Half of the problems could be prevented by cleaning it seems. But not knowing what to clean and how is giving me a crash course.
    But once I know I can't blame any one but me. But thanks again
    D.Tibbitt Thanks this.
  5. Long FLD
    Long FLD Road Train Member
    13,203
    55,502
    Mar 4, 2015
  6. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Wt5for. qt55ըտԸգ*
    583,417 miles
  7. Antinomian
    Antinomian Road Train Member
    2,218
    3,562
    Feb 17, 2013
    Wet? You may have an EGR cooler leak. Are you losing any coolant? Pull the crossover pipe and check for coolant.
    feldsforever and D.Tibbitt Thank this.
  8. QUALITYTRUCK
    1,820
    1,787
    Jun 14, 2009
    romulus,mi
    Replace the Delta P sensor. Remove the crossover pipe and inspect the ports. Probably clogged.
  9. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Yes on the cool ant leak.
  10. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Will so this weekend
  11. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Check for soot in the coolant tank . Is your coolant darker than normal?
