DD13 no crank no start
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wtokhi, Dec 10, 2020.
  1. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    hey y’all,
    It’s been a while since I posted, changed jobs and everything new shop, we towed in a cascadia daycab 2014 dd13 yday for a no start no crank issue, it just clicks when trying to start, it’s an auto shift dt12 transmission. the starter was changed, the ignition was changed, and the def light was flashing low even when full so the def pump assembly was also changed, at this
    Shop they use a diagnostic program called jaltest which I hate since I’m used to diagnostic link, we swapped ecu’s with another same truck and still no luck it just clicks, it does not start when the starter is bypassed either, I checked and there is no signal coming to the solenoid wire so I’m assuming the ecu is blocking it? All relays and fuses were checked and there are no codes, however here’s where it gets interesting, the transmission display started showing F for fault, also the diagnostic program will not connect to the transmission module and says there’s a communication error even tho it connects to all other modules no problem which makes me think the Transmission ECU is the problem, I retrieved the codes from the trans display instead and it shows codes 21, 25 and 35, 36 but each one randomly, these also point to the trans ecu, so apart from no signal at the starter, the def light flashing, and no connection with the program, what else could it be? Am I on the right track? Any advice? Where do I go from here?
  3. Antinomian
    Antinomian Road Train Member
    2,175
    3,449
    Feb 17, 2013
    The master power cutoff switch sometimes goes bad on Cascadias. On my 09 it was under the cab on the driver's side. On my 16 it's a switch on the floor beside the drivers seat.
  4. wtokhi
    251
    115
    Nov 3, 2017
    There is no power master cut off switch in this truck, the truck has power but will not crank
  5. Antinomian
    2,175
    3,449
    Feb 17, 2013
    Here's a video of a problem that looks like it might be similar to yours.
  6. Hyedgar
    Hyedgar Bobtail Member
    I have The same problem on my truck please let me know If you figure out what the problem is
  7. wtokhi
    251
    115
    Nov 3, 2017
    it ended up being the CPC, the common powertrain controller located in the dash, before you change that, check your PNDB, the powernet distribution box on the firewall by the steering column, check the fuses in there, if not that then id say CPC, before buying it since its really expensive and requires programming, see if you can find a truck with the same year and transmission and swap it out before you confirm that is the issue
    BoxCarKidd and lwlevens Thank this.
  8. AKA Trucking
    AKA Trucking Bobtail Member
    I have had the same problem with a 2016 Cascadia. with a 10 speed manual trans. No start. ( just clicking) while turning the key. Also had red flashing light in the DEF gauge with no green bars even though DEF tank was full. There also was no yellow engine light present when the key was turned over.
    Troubleshooting included the following: had power going to the starter, checked fuses, & relay on drivers side fender fuse box. Power Distribution Box on firewall checking all fuses, connections going in and out all were good. Checked clutch switch. It was good. Power switch on the floor was good too. I swapped a CPC from a sister truck, plugged it in and the truck fired right up. DEF gauge read normal with all green bars present, no flashing red light and yellow engine light was present once ignition was turned on and went out once truck started. Just to be certain that the CPC was the root cause of all the said issues, I took the bad CPC from the the problem truck over to the donor truck and plugged that CPC in it's place. Every issue that was wrong with the problem truck now existed in the donor truck. So a new CPC will need to be purchased and it will also need to be programmed before it is reinstalled. I hope this post will help someone experiencing the same issue.
  9. Antinomian
    2,175
    3,449
    Feb 17, 2013
    I saw this a while back. Maybe it will help you.
  10. wtokhi
    251
    115
    Nov 3, 2017
    sorry for never updating this thread, CPC was the issue on that unit
