DD13 oil pressure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Northwinds1, Aug 21, 2019.
  1. Northwinds1
    Northwinds1 Bobtail Member
    41
    5
    Mar 11, 2013
    DD13 engine running 5-10PSI oil pressure at idle after changing engine oil and filters. Alarm and engine shutdown. Detroit diesel correct filter used with 10w30 oil. By pass valve at top of filter seems to be working and springs back. Ran a mechanical gauge from oil pressure port and still 5-10PSI. Should there be a check valve at the bottom of the filter housing? No issues before the oil service.
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    what year is your engine?
    could be bad O-rings on pickup tube.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    Did you change the oil yourself? Was the fuel filters changed at the same time?
  5. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    He will get hearth attack if you will explain him that engine is gone.
    uncleal13 Thanks this.
  6. Northwinds1
    41
    5
    Mar 11, 2013
    2015. 173k mi. Different tech did the service. I did see him replace the oil filter and everything looked correct when I took the filter out to double check. Unless the stand pipe has a small crack somewhere we cant see. Open port on the bottom inside of housing next to the stand pipe. We dont do much with DD.
  7. uncleal13
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    @mhyn probably right then about o-rings in tubes in oil pan. Cheap fix. There is a video on YouTube about it
  8. uncleal13
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
