DD13 sensor with orange jacket, what is it
Discussion in 'Freightliner Forum' started by shatteredsquare, Jun 29, 2021.
  1. shatteredsquare
    shatteredsquare Road Train Member
    1,407
    1,841
    May 23, 2014
    middle dirt
    the big silver plug, the only one with the orange jacket, on driver side under intake, what is it? its starting to squirt soot on stuff below and around the sensor, looks like printer toner. ~420k miles on engine
  3. Cattleman84
    Cattleman84 Road Train Member
    10,034
    71,715
    Nov 1, 2017
    The Sticks, Idaho
    Pictures would help.
  4. shatteredsquare
    1,407
    1,841
    May 23, 2014
    middle dirt
    the plug with the orange jacket, on driver side of 2017 DD13 below intake stuff. it's starting to leak soot out from around the sensor seal
  5. shatteredsquare
    1,407
    1,841
    May 23, 2014
    middle dirt
    screw ring holding it in was hand loose. anybody know what it is
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    The orange is indication of 120 volt ac power. It’s an engine block heater. The heating element is immersed in an engine coolant passage.
  7. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    The ring is just a retainer to hold the cord to the heating element of block heater. This Heating element is threaded into oil/coolant module and has an o-ring seal. This will not be leaking soot, as it is in coolant. The soot is from another source like the cold boost pipe or intake manifold. Anything downstream of the EGR the comes around the front of engine and gets mixed into the cold boost pipe.
    Magoo1968 and AModelCat Thank this.
  8. shatteredsquare
    1,407
    1,841
    May 23, 2014
    middle dirt
    it must be coming from the intake gasket above it, can't see how tf there is soot all around and behind the block heater plug but none actually on it. intake isn't loose but there's one bolt that looks impossible to get to on bottom left corner, the same dealership that left my compressor hose unplugged replaced the coolant line and i bet the intake tube had to come of to do the coolant line. or maybe it just good time for a new leak. always a good time for a leak
