DD15 code RSRVC 128s 146 14 and issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MTMAUS, Jan 29, 2023.
  1. MTMAUS
    MTMAUS Light Load Member
    263
    218
    Sep 28, 2019
    Hey, I have 2 freightliners with a DD15 in them.
    Truck 1 - I am getting fault code
    RSRVC 128s 146 14, both engine lights come on. Both solid orange
    It comes on and off, might be on for a few hours or a few mins. Truck will still do a regen when the DPF light comes on.
    Can anyone let me know what the code refers to?
    Truck 2 - when turning the ignition, I just get a single click at the starter, sometimes Truck will turn over fine, and when it does it has no issues and cranks fine. I tested all the batteries and they are good.
    It started off with doing it just once a month but has progressed through every other time.
    I have checked all the grounds and am thinking it's the starter, Truck is a 2017 and has 1.3mill kms on it, and I think it's the original starter. Anything else I should check before pulling the starter?
    Thanks for any assistance.
  3. LakenT
    LakenT Bobtail Member
    26
    4
    Jun 19, 2022
    I have ran into this issue. We went months with one of our trucks click click click then it start. We would have to turn the key multiple times. One day at a receiver we turned truck off and did not start back up. I ended up having to drive to St louis to put a starter on one of our trucks. If it does the click click and then just put a new starter on it. Its the selinod on starter. Just spend 250 dollars and fix your problem.
  4. MTMAUS
    263
    218
    Sep 28, 2019
    Yeah we don't get click, click, click. Just a single solitary click. So I am pretty sure it's the starter, I wish starters where $250, he in AUS they are more like $600 plus fitting (may do it myself, maybe)
  5. LoneRanger
    LoneRanger Road Train Member
    3,698
    9,619
    Jun 3, 2018
    Bench test the starter if you can, hope that helps.
