DD15 coolant temp issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Oleg D, Apr 19, 2026.
  1. Oleg D
    Oleg D Bobtail Member
    24
    12
    Jun 29, 2021
    Canada
    “Hello everyone, I’m looking for a coolant flow diagram for a Detroit Diesel DD15. We’re having an issue with a Freightliner Cascadia where the engine cools down quickly when not under load. While driving downhill, the temperature drops to about 150°F, and at idle it won’t go above that. The thermostat have already been checked and replaced. Any advice or suggestions would be greatly appreciated.”
  3. JB7
    JB7 Road Train Member
    1,136
    2,074
    Dec 13, 2022
    Laurel, MD
    Drops to 150 according to what, the gauge on the dash? What is the ECM reading for engine temperature. What is your coolant protection at? Too much or too little antifreeze (which also raises the boiling point) can cause problems. What is the fan clutch doing, is it on all the time?
  4. Magoo1968
    Magoo1968 Road Train Member
    2,120
    5,661
    Mar 18, 2021
    St Malo mb
    Fan is on or bad faulty replacement thermostat on older models will do that on newer models it could be a problem with the variable speed water pump. We convert out variable speed water pumps to old style and reprogram computer when they need replacement instead of paying a grand every time for a inferior product in the mountains.⛰️
    Rideandrepair and JB7 Thank this.
  5. khurmiDiesel
    khurmiDiesel Bobtail Member
    13
    5
    Apr 5, 2026
    Water pump could be faulty
    Rideandrepair Thanks this.
