DD15. Doc face pluging
Discussion in 'Freightliner Forum' started by Vegas unlimited, Feb 18, 2020.
  1. Vegas unlimited
    Vegas unlimited Bobtail Member
    37
    43
    Feb 18, 2020
    What can cause doc face pluging? No fault codes. Doc face pluging happened about a month ago. We cleaned it by running the engine 5-6 hours Diagnosticlink connected. It was cleaned. Now again pluging happened. We have checked injectors, turbo, air filter. Everithing is ok. Any ideas?
  3. AModelCat
    163,717
    Is EGR cooler leaking?
  4. Vegas unlimited
    37
    43
    Feb 18, 2020
    No. Checked.
  5. Antinomian
    Antinomian Road Train Member
    2,163
    3,424
    Feb 17, 2013
    How many miles on the truck? I've heard that the catalyst can wear out, which would mean not enough oxygen being produced during regens. Seems like regens would start failing for lack of heat if that were the case though.
    Vegas unlimited Thanks this.
  6. Antinomian
    2,163
    3,424
    Feb 17, 2013
  7. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    maybe a leaking doser/aftertreatment injector spraying diesel when it shouldn't be? have u noticed a slight increase in fuel consumption?
  8. Vegas unlimited
    37
    43
    Feb 18, 2020
    Its 1 year old one box
  9. Vegas unlimited
    37
    43
    Feb 18, 2020
    I will check the doser tommorow..
  10. Leo2000
    Leo2000 Bobtail Member
    Hi im new here .looking for some help. I have a 2017 cascadia dd15 , all 3 engine lights are on only tree codes (each one of them just indicate a particular lamp is on) no indication that a sensor is bad or else. The problem continue when you start regen the engine goes like there is a missed and the egr valve actuator keep going back and forth it takes like 5 minutes or more you feel the engine sound change(no more miss) but still high idle and you can feel there is no regen taken place. Any help?
  11. Vegas unlimited
    37
    43
    Feb 18, 2020
    Leo sorry i dont know what is the problem with your engine.
