I have a 2010 cascadia DD15 when I push the switch on the steering wheel it turns on the light on the dash switch but doesn't activate the engine brake. Any advise on what to try?
DD15 engine brake problems
Discussion in 'Freightliner Forum' started by Manock89, Dec 2, 2017.
Is your truck manual or automatic?
Its a manual 10 speed Eaton fuller
It may be the clutch switch going bad. If the top of your clutch not striking the clutch spring, sometimes the jakes and cruise won t engage until you pull the clutch towards you and it strikes the clutch switch
When I push it in a little with my hand I can hear a click. Is that the clutch switch you are reffering to?
It may be. If you look at the top of the clutch pedal, you will see a square switch with about a 3 inch spring coming from it
That's not what a clutch switch on a cascadia looks like...
Does your cruise work? Does it work if you tap the brake pedal?
