DD15 , fuel/air problem , not constant / need help
Discussion in 'Freightliner Forum' started by Emil Baran, Aug 15, 2017.
  1. RocketyMan
    RocketyMan Medium Load Member
    554
    337
    Jun 5, 2015
    Hmmm....We really need to test the delta P circuit to the MCM.
  3. Gus4800
    Gus4800 Bobtail Member
    5
    Nailed it.
  4. Gus4800
    5
  5. John69
    John69 Bobtail Member
    4
    Mar 4, 2021
  6. John69
    4
    Mar 4, 2021
    I just replaced her cooler
  7. John69
    4
    Mar 4, 2021
    Ops egr cooler
  8. bbrothers1
    bbrothers1 Bobtail Member
    Ok I’m having this EXACT same issue. Bought my with almost same mileage and been fighting for weeks with this. Replaced delta p sensor and codes came back on with 500 miles. Took off egr and heat pipe and cleaned everything but still nothing. Within 2 days I had to have a call out to do a computer forced regen because the truck won’t with the check engine lights on. This was my 4th one of these in the last 3,000 miles because it wasn’t doing them. Determined that DPF filters needed cleaned out and replaced sensors (about $3,600 and I was stuck in a hotel for 8 days). Still no fix on the codes, random dying issue or the 25% derate I’m running in due to the codes still. Any solutions?
  9. resp59
    resp59 Bobtail Member
    17
    Feb 15, 2014
    South Dakota
    I fixed my intermittent boost issue by pulling the delta p pipe off and blowing open the ports. I used carb cleaner and compressed air. It fixed it. the one port was clean, the other plugged. this after I replaced the Delta p sensor... There is a bend in the ports, so a straight hanger or drill bit won't clean it right. You might be able to get a zip tie down, I couldn't on one, the other I could.
  10. Lockport
    Lockport Light Load Member
    201
    131
    Mar 26, 2011
    Lockport, MB, CAN
    Replace the venturi pipe. Last one I bought was under $100
