DD15 low engine horsepower
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Victor c, May 26, 2018.
  1. Victor c
    Victor c Bobtail Member
    6
    Have cascadia that was dynod has a dd15 engine 455 hp but only put 328 hp max on dyno why?
  3. gwbushsucked
    gwbushsucked Bobtail Member
    May 26, 2018
    U need to get it turned up dd15 can go up to 565 or 570 under warrinty
    Victor c Thanks this.
  4. Pedigreed Bulldog
    7,737
    14,425
    May 7, 2011
    455 rated x 80% loss through the drive line is 364 hp. What rear end gears are in it? 2.xx will further reduce the hp shown on a chassis dyno. Where was it done? High elevations, hot temps, etc...can all work to reduce the number, too. Then, if it's a high mileage engine, things aren't as tight as they once were and the power numbers suffer a little more. Add it all together and you start approaching the 328 hp it showed.
  5. Victor c
    6
    Thank you guys so much for replying It has a 3.42 gear ratio 504,000 miles and
    Is it normal to drop so much?
  6. Victor c
    6
    How do i do that?
