DD15 low NOx conversion efficiency and bad DEF Quality
Discussion in 'Freightliner Forum' started by janboskit, Jun 28, 2016.
  1. tallmon
    tallmon Medium Load Member
    657
    321
    Oct 22, 2014
    That really sucks. Search the forums or YouTube for"nox outlet sensor breath fresh air"
  3. Freighliner DD15
    Freighliner DD15 Bobtail Member
    13
    Apr 3, 2020
  4. Freighliner DD15
    13
    Apr 3, 2020
    I forget to mention I did replace outlet and inlet sensor as well and codes comeback. The shop said I need new SCR One Box.
  5. Motto
    Motto Light Load Member
    102
    126
    Apr 10, 2020
    Yes you need it. But do you really want to spend 15k on that truck ?
  6. Driverdad
    Driverdad Light Load Member
    159
    171
    Jun 13, 2015
    You can take the Nox outlet sensor out of the exhaust and let it breath fresh air . You can follow the wire attached to the outlet sensor up to a box You would need to tuck the sensor inside that box to keep it dry . You can delete the codes with a OTR Reset Tool
    This will save you 15000$
    It will still throw a code for an illogical nox output but wont derate
    Vitkouski, armo and uncleal13 Thank this.
  7. Antinomian
    Antinomian Road Train Member
    2,193
    3,492
    Feb 17, 2013
    Hope you saved the old outlet sensor. You'll need an extra one to do the bypass. Here's a video on how to do it:
    Freightliner Cascadia DD13 DD15 SCR filter bypass
    Vitkouski and DieselDisciple Thank this.
  8. Motto
    102
    126
    Apr 10, 2020
  9. Freighliner DD15
    13
    Apr 3, 2020
    Thank you
    Motto Thanks this.
  10. Antinomian
    2,193
    3,492
    Feb 17, 2013
    So what was the outcome? Did you just pull the sensor or did you buy a one box?
