DD15 low NOx conversion efficiency and bad DEF Quality
Discussion in 'Freightliner Forum' started by janboskit, Jun 28, 2016.
  1. A gear per tire
    A gear per tire Bobtail Member
    40
    10
    Jan 26, 2019
    Hey, does anyone know if there is a way to program the ACM to inject more DEF? I noticed that when it injects more DEF the efficiency goes up on this one truck. Or is there no way to compensate?
  3. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,606
    Jun 3, 2018
    Do you know if the amber engine light stays on if the bypass is done? Not the CEL.
  4. Truckers Report Jobs
  5. Antinomian
    Antinomian Road Train Member
    2,178
    3,465
    Feb 17, 2013
    I don't know directly. I've heard that you do get a code on post-EPA07 engines so I assume yes. I didn't use the bypass method on mine when a NOx sensor failed. I used the DDDL software to change the derate consequences to nothing. I was getting a CEL, a MIL, and a DEF warning light. The CEL and DEF lights would go out after a while but the MIL stayed on.
  6. LoneRanger
    3,695
    9,606
    Jun 3, 2018
    i appreciate it. I don’t want to spend $$ on the one box if I have 8 months left on my career.
    bypass it is and learn to live with the MIL.
  7. armo
    armo Light Load Member
    274
    290
    Jun 16, 2022
    MIL amber light will stay on and there will be one active fault code. just ignore it. i drove 700k miles with that code active )))
    LoneRanger Thanks this.
  8. Toey84
    Toey84 Bobtail Member
    16
    5
    Dec 30, 2020
    Bakersfield CA
    will this take care of 5 MPH derate?
  9. LoneRanger
    3,695
    9,606
    Jun 3, 2018
    older dd15’s work, I think the cut off was 2014
  10. Toey84
    16
    5
    Dec 30, 2020
    Bakersfield CA
    Ours is a DD13 (2014) in the process of replacing DEF pump corrected nox efficiency with fresh air now my DEF pump fault came active however my nox efficiency is 100% . I will let you know how it works out .
  11. Toey84
    16
    5
    Dec 30, 2020
    Bakersfield CA
    Update truck is running
    xsetra Thanks this.
