DD15 oil in harness, issues?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MTMAUS, Jun 21, 2024.
  1. MTMAUS
    MTMAUS Light Load Member
    263
    217
    Sep 28, 2019
    Hey, my oil pressure sensor just blew out and oil coming out of it pretty bad.
    Do I need to worry about oil in the harness and going up to ECM?
    I havent pulled it apart yet, but would be very surprised if oil isnt in the harness.
    Anything I need to do to the harness? Can it do anything to the ECM? Or just pull out the sensor, clean everything up and plug it back in?
    Thanks
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    This is going to cause a fight, but I just brake clean it, blow it out with shop air. The argument is some think the oil will penetrate the ecm and short it out. If that were true, any injector connector under the rocker cover exposed to oil would short out in literally two minutes after you start the engine.
  4. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    I agree with Heavy
    ISX oil pressure sensors leak all the time. Spray connector out with contact cleaner and run it.
    Heavyd Thanks this.
  5. MTMAUS
    263
    217
    Sep 28, 2019
    All good, the wires going in werent as bad as I thought, so yeah, I just used brake cleaner, thanks heaps.
  6. Ridgeline
    22,726
    123,456
    Yep you really have to worry about the oil atoms mixing it up with the electical atoms and confusing the ECM to which atoms it should listen to. The oil atoms will only talk about pressure while the electrical ones will only talk about voltage and current, what a mess it will be.
    OK fun aside, just do what Heavyd said, clean it up and run it.
    Heavyd Thanks this.
