Dd15 oil leaking From breather
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oscarv, Jul 21, 2022.
  1. Oscarv
    Oscarv Bobtail Member
    Jul 20, 2022
    So I’ve had this truck for 3 years now bought it used 450k now has 818k yesterday I was climbing a steep grade and noticed what looked like smoke in a distance out my mirrors and shortly after smelled it... pulled over and checked to make sure it wasn’t me... well it was me I had tons of blow by smoke out of the breather filter it never smoked... shut the truck off coolant instantly leaked out overflow tank .. topped it off again and checked oil level looked good 55-60 psi while climbing cabbage hill. Uncoupled attempted to drive it back to the yard not even 45 sec later low coolant stop light added coolant again 1 min later did the same thing checked oil and oil is getting in coolant now starts turning milky... any ideas oil cooler possibly?I’ve never changed the filter to the breather system ... this truck has never gave me a issue in roughly 400k miles aside from fuel pump and dpf cleaning any help is greatly appreciated.
  3. Big Road Skateboard
    7,556
    43,395
    May 2, 2021
    Probably blown head gasket or warped head. Did it overheat? I've seen several warped heads on a DD15. Warped so bad you could see it after pulling head bolts.
    Sounds like your getting compression into your cooling system
    Dirk Diggler and LoneRanger Thank this.
  4. baha
    baha Road Train Member
    4,136
    2,837
    Jul 25, 2013
    ga
    Call for a tow to a shop that someone can recommend if you can tell them where you are, bad things like needing a new crankshaft will happen if you try to drive with milk looking oil from a bad part?
  5. armo
    armo Light Load Member
    274
    291
    Jun 16, 2022
    liner's seal/o-rings ... the bottom ones... overhaul !
  6. Big Road Skateboard
    7,556
    43,395
    May 2, 2021
    Water in oil, yes, but wouldn't cause it to push out water
  7. armo
    274
    291
    Jun 16, 2022
    this engine is done. Inframe. could be head gasket too or head
  8. Rideandrepair
    17,599
    56,989
    Aug 8, 2015
    Pushing coolant, probably blew the already weak oil cooler. Need to find out if it’s building pressure in the coolant, before anything,
  9. Chieftains
    Chieftains Medium Load Member
    366
    901
    Jul 18, 2021
    If it's leaking oil heavily from breather. Than it's the crankcase canister filter. About 300 bucks.
    Have to change the whole thing. It's a one time filter.
    Double check where it's leaking from before a big bill comes
  10. Dirk Diggler
    Dirk Diggler Light Load Member
    56
    170
    Jul 15, 2022
    It’s a blown head gasket/ warped or cracked head.
