DD15 oil pressure sensor leaking? Removal and Replacement Advice
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Jan 4, 2019.
  1. PE_T
    PE_T Road Train Member
    I wouldn’t force it out. Just pull it up until it stops.
  3. 9400i
    9400i Bobtail Member
    32
    17
    Mar 2, 2014
    olathe,kansas
    What size deep well socket do you need?
  4. PE_T
    27mm or 1-1/16” deep socket. If you have both, use the one that is deepest. Mine barely made contact. I wasn’t able to find the actual torque spec, but I used 44 ft lbs, which is a common spec for various bolts in the DD15.
  5. Motto
    Motto Light Load Member
    102
    125
    Apr 10, 2020
    Good job guys..
    PE_T Thanks this.
