DD16 EGT Gauge Install
Discussion in 'Ask An Owner Operator' started by Phoenix Heavy Haul, May 10, 2024.
  1. Phoenix Heavy Haul
    Phoenix Heavy Haul Medium Load Member
    469
    1,398
    Feb 8, 2022
    Raleigh NC
    So I need to install an EGT gauge on my 122SD with a DD16. From what I understand there is a factory EGT sensor installed right after the DOC which communicates with the ECM eliminating the need for a factory gauge.
    Since my DOC was damaged and a new 1box was 15k I went a different direction with repairs. Now I need a gauge on my dash to properly monitor my EGTs.
    Is it possible to use the factory probe, and wire a gauge into it or should I put in a new probe and wiring harness?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Generally all of the factory sensors in the exhaust system are digital and would not work with a standard analog gauge.
    Phoenix Heavy Haul Thanks this.
  4. Ridgeline
    22,744
    123,736
    It should be a K type probe, and you will need to get a kit for it either way. You can not use just plain wire with it, it has to be a specific type and length. Ask a Detroit or Freighliner dealer for the parts and have them install it.
