DD16 Western Star
Discussion in 'Ask An Owner Operator' started by JohnAyala999, Jan 5, 2024.
  1. JohnAyala999
    JohnAyala999 Bobtail Member
    37
    22
    Sep 22, 2022
    So I’m in the market for a newer used truck and I have an opportunity to buy a Western Star for a what seems to be a good price but it’s a 560 hp DD16 with 3.08 gear ratio with DT12 transmission and I will primarily be doing general freight via 53’ Flatbed so will be 70-80k most of the time also I will be doing mostly Texas to Texas so mostly flat-ish highway but i feel this engine may be too powerful so I guess my question is 560hp DD16 too much how would this affect and do you guys have any other trucks/engines that you like for this kind of work I’m open to all opinions Thank you in advance
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,086
    Dec 15, 2021
    I would prefer the more horsepower,it will probably lower your mpg a little but you'll have the hp when you need it.
    JohnAyala999 Thanks this.
  4. Blagoje
    Blagoje Medium Load Member
    441
    961
    Jul 14, 2022
    Paris, Illinois
    I agree, go big or go home. I thought bigger was better in Texas???
  5. Knightcrawler
    Knightcrawler Road Train Member
    1,766
    6,913
    Apr 10, 2017
    Mpls, Mn oops Ocala, Fl.
    The only problem with a DD16 is you will likely be over the 12,000 steer and need special tires (at 12,500) and I think weight class/permits.
  6. JohnAyala999
    37
    22
    Sep 22, 2022
    Oh wow I never thought of that. so glad you brought that up
  7. AModelCat
    164,645
    The emission systems need heat to work properly. Power is good but making the engine pull hard through out the day is good for it.
  8. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,478
    Mar 18, 2021
    St Malo mb
    Dd16 is only 150 ish lbs heavier but needs a stouter driveline that where the additional weight comes from.. with 3.08 it should be in its torque band . PS do a ecm download to see problems and lifetime fuel economy.
  9. JohnAyala999
    37
    22
    Sep 22, 2022
    Ha ha that definitely is a good thing to think about
    Blagoje Thanks this.
  10. JohnAyala999
    37
    22
    Sep 22, 2022
    Yes will do! Thank you
  11. JohnAyala999
    37
    22
    Sep 22, 2022
    Yeah I’ve heard this before
