ddec ii to ddeciii/iv conversion
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Nov 1, 2018.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    good day folks whats all is needed to covert from deecii ecm to a ddec ii/iv ecm?
    i heard is all i have to do is add in the ddec ii/iv power plug, then have ecm calibrated
    singlescrewshaker Thanks this.
  3. singlescrewshaker
    4,880
    42,752
    Dec 31, 2017
    Little Havana, FL
    Good ? I too have a ddecII and have also wondered if it's possible to go to a ddecIII. I believe my FLD only has an OBD one port also, so I've still not been able to check/alter any of my ecm settings..
  4. catwrench55
    catwrench55 Light Load Member
    211
    88
    Jan 5, 2015
    Biggest hurdle in the relucter wheel on the crankshaft is different, requires disassemble front cover to change. I believe their are a few other sensors that are different but that is the biggie
  5. Trcknwolf
    Trcknwolf Light Load Member
    57
    27
    Nov 24, 2010
    Bellevue, NE
    My suggestion is be happy with what you have!! However, if you are not, you can't "convert" your DDEC 2 ECM to a DDEC 3/4 ECM. They are two completely different animals. There isn't an aftermarket kit you can buy, no special doodad or gimmick & no magic wand you can wave to make it so. Somebody has provided you with bad, uninformed information. The only solution is this: you need to buy EITHER a newer complete DDEC 3/4 engine including all the wiring, ECM, etc for the specific truck you have & do a swap OR buy a truck that has a DDEC 3/4 engine. A little history: as you may or may not know, your DDEC 2 engine is a lower horsepower/torque engine--usually 370h-430hp with a max of 470hp. The torque rating is also lower @ 1350-1550 ft lbs max. Trucks with these lower hp & torque DDEC 2 engines usually ran 3.70, 3.90 or 4.11 gearing to make up pulling ability. 3.90 gearing was the most common. I'm not going to list all the differences between the DDEC 1/2 engines & the DDEC 3/4 engines as there are too many. However, this is the most important point I make---its a structurally weaker engine, both in block & head design as well as internal parts design. An example is the use of 2 piece pistons with bolt-on piston skirts. A STUPID IDEA!!! Therefore, all of the performance upgrades on the market are NOT available for the DDEC 2 engine. While the DDEC programming overall is pretty basic & simple, the DDEC 3/4 ECM is much more advanced than the DDEC 2 ECM.
    truckerbangin and swaan Thank this.
  6. tshot2020
    tshot2020 Bobtail Member
    Apr 9, 2019
  7. tshot2020
    Apr 9, 2019
    18SP546 GOOGLE IT
  8. singlescrewshaker
    4,880
    42,752
    Dec 31, 2017
    Little Havana, FL
    DDEC II -- DDECIV wiring harness & hardware conversion. Nice, thanks for the info. I'll be checking into this..
    tshot2020 Thanks this.
  9. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    The only one with bad, uninformed information is you. People upgrade from DDEC 2 to 4 all the time. Just because you don't know how to do something doesn't mean it can't be done
  10. Elliot transportation
    Elliot transportation Bobtail Member
    I am finding out my self that it is a bit of a challenge if the engine family main frame flash is not correct Detroit had to write a custom tone wheel input in order for my truck to fire and i am currently still dealing with all the other inputs and outputs for cruise , Jakes, fuel pedal and , service brake my old engine harness and ecm works completely fine but when i switched from ddec 2 to ddec 4 the computer is Loki g for inputs and outputs that are not on my factory freightliner harness due to the age of the wiring and minimal requirements for my old system back at freightliner for the 4th time to get the base program write than my friend and tune it what a mess !
  11. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    Have to change the relucter wheel count in the ecm i knows that do this all the time
