DDEC3 to DDEC4 parts
Discussion in 'Ask An Owner Operator' started by Old dirty trucker, Mar 16, 2022.
  1. Old dirty trucker
    Old dirty trucker Bobtail Member
    41
    47
    Oct 24, 2021
    My 96 DD3 blew up on me, what parts can I salvage. Jakes, injectors, etc. I dropped a 02 MK60 in it my old engine was a 96 GK60 wold like to salvage what I can if it doesn’t get rebuilt. My ECM was a DD3 so I know I can’t reuse it for a spare. That SUX
  3. Rideandrepair
    17,578
    56,942
    Aug 8, 2015
    That’s a good question. I think jakes and injectors would have to be used together, if at all. I think the adjustment specs on jakes are different. Newer ones don’t back off, different injector heights? I’m not sure. You can look it all up in Detroit manual. Probably sell it as a core, if the blocks good. If not, I’d definitely keep the inner and outer front covers, if they’re still good. They’re $1000-$2000 used, if you can find them. Also the rear cover. Any accessories, like the fan, if only for a core, or to rebuild for yourself. Heads worth something as a core. Flywheel, intake, exhaust , oil cooler housing. Oil pan, whatever’s left. Never know when you’ll need it. Can always sell the parts.
    Old dirty trucker Thanks this.
  4. Old dirty trucker
    41
    47
    Oct 24, 2021
    That’s what I thought to, I’ve took the water pump, air compressor and three piece jake off and reused so far. It had a 2 piece on it. So I guess I run the over head the same just gap the jakes like I did on my 96 engine ,and the valves and injectors for what the engine model calls for Thanks for the reply
  5. Old dirty trucker
    41
    47
    Oct 24, 2021
    Oh also the old style tensioner (just a big not and bolt) and also use acc drive gear
  6. Old dirty trucker
    41
    47
    Oct 24, 2021
    Got my truck running Friday after we swapped fuel pumps. Man it sounds great. We hooked up to the ECM and to my surprise it was a 500hp stock tune of a 2000 BK. My truck is a 2002 470 MK. He gave me the wrong ECM but I’ll keep it because of 30 more hp for free. Any problems I should know about this??? or should I try and get the original for the truck. He said he had 3 if it didn’t work just let him know
