decent hydraulic jack, decent price where?
Discussion in 'Ask An Owner Operator' started by Rockwind1, Oct 21, 2022.
  1. Rockwind1
    Rockwind1 Bobtail Member
    27
    9
    Sep 22, 2022
    i've had bad luck with the wal mart hydraulic jacks,, great price but on 2nd one now. i wanted to put a jack in my trailer box cause if it is loaded and i need to change tire, it will be heavy.
    has anyone found a good solid brand of hydraulic jacks that won't break the bank but also won't break when you need it?
  3. rollin coal
    rollin coal Road Train Member
    13,832
    28,716
    Mar 29, 2008
    TN
    I like the air assisted 12 ton hydraulic jack that I got from Harbor Freight many years ago. I caught it on sale for about $90. 12 Ton Air/Hydraulic Bottle Jack
  4. Rockwind1
    27
    9
    Sep 22, 2022
    i think i need a hydraulic one,,, i don't have air,, i am pulling 30ft gooseneck with 2 10k axles with a f350
  5. 062
    062 Road Train Member
    6,390
    34,169
    Oct 20, 2013
    I’d go heavier than you think you need. I had a 12 ton hydraulic like RC posted and really needed a cheater pipe to get a axle up.
    Harbor freight or northern tool would be where I would look.
  6. Diesel Dave
    9,931
    34,878
    Jan 20, 2010
    Hesperia, Ca.
    Times 2 on the Harbor Freight jacks. I have about 4 bottle jacks laying around, 2 are from Harbor Freight.
    God prefers Diesels and Rockwind1 Thank this.
  7. 062
    6,390
    34,169
    Oct 20, 2013
  8. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    20 Ton Hydraulic Bottle Jack
    This one works well, although I'd rather have a jack with a case to protect it. I've also got the low profile version of it as well. It will fit under my trailer and drive axles easy, but not the steer axle. You might need a block or something to lift it at a higher point like near the spring hanger. I think it lasted about 4 years before I finally had to put more oil in it.
  9. rollin coal
    13,832
    28,716
    Mar 29, 2008
    TN
    Bigger probably better if you don't have an air source handy.
  10. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    Every one of these big bottle jacks with an air motor come with a handle for armstrong operation. At least that way you'd have it if you were working near air, or at some point brought along a small compressor.
    God prefers Diesels and loudtom Thank this.
  11. RedForeman
    4,875
    22,141
    Jan 30, 2011
    If Milwaukee would come out with a 20T jack that ran off a M18 battery it would sell like hotcakes.
