Decrease in MPG by 1 point... Tires to blame?
Discussion in 'Ask An Owner Operator' started by Rubys0h0, Oct 15, 2021.
  1. Rubys0h0
    Rubys0h0 Bobtail Member
    13
    16
    Apr 23, 2020
    I used the Michelin rolling resistance comparison tool and it says there's only a 6-point difference between my old drive tires (Michelin XDN2 275/80 R22.5) and my brand new ones (Kelly KDA 295/75 R22.5)
    So then why did my MPG average decrease from 8 to 7?
    Is that even possible, or could it be a different problem?
    77fib77 Thanks this.
  3. Long FLD
    Long FLD Road Train Member
    12,979
    54,457
    Mar 4, 2015
    How long is the 1 mpg drop average for? Also keep in mind you’re going from a relatively worn down tire to one with nearly an inch of tread on it too.
    Rideandrepair and beastr123 Thank this.
  4. Rubys0h0
    13
    16
    Apr 23, 2020
    Nearly a full inch. These KDAs are thick as hell, super deep grooves.
    I've tracked the average for 8 full weeks at around 3000 miles a week.
    Rideandrepair Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,781
    9,221
    Jul 12, 2017
    New tires can decrease mileage slightly. Deeper tread=more resistance. As they wear smooth with less tread flex and the lower the depth is when you can get your best milleage. Keep them air as hard as you can.
  6. jamespmack
    Compair revolutions per mile and adjust ecm to new tires.
  7. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Don't forget to rotate them every 20k to keep the feathering at bay while you deal with the new tire "squish". Aren't new tires great?!
  8. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    Kellys are more of a farm tire IMO. Like if your hauling grain, running gravel roads, etc. So, you went from one of the best tires in the business to a mid range non OTR tire.
  9. lester
    2,957
    8,088
    Jan 2, 2012
    NW, Iowa
    You went from a high end tire to a middle of the road high traction tire
  10. Big Road Skateboard
    7,234
    41,190
    May 2, 2021
    Exactly. You went from a premium to a mid grade tire. Fuel economy will suffer.
  11. jamespmack
    I like and respect your content and knowledge. Higher psi is better for mpg, but decreases ride quality and wear. It is a mega fleet way of thinking. Need to really find balance that works for each individual operation. Every tire has a operation range.
    I run 95 in steers, and 90 on trailes and drives. It works just fine for my operation.
  12. Diesel Dave
    9,759
    33,578
    Jan 20, 2010
    Hesperia, Ca.
    I’ve ran a set of Kelly (8) drive’s tall rubber (11.24.5) KDA. Back then I paid $325 each brand new. It was a deal I couldn’t pass up. Had very good luck with them, but like stated above, when they start feathering, it’s time to rotate.
    Rideandrepair, Dave_in_AZ and Rubys0h0 Thank this.
