Deer guard question
Discussion in 'Experienced Truckers' Advice' started by DUNE-T, Nov 6, 2025.
  1. DUNE-T
    DUNE-T Road Train Member
    7,054
    17,193
    May 10, 2015
    Detroit, MI
    For those lucky ones who hit a deer few times already, is there a benefit of buying a bigger deer guard?
    From the looks it does offer more coverage, but does it really matter in al life since impact gonna be happening on bumper level anyway?
    I just hit my first deer and seems like if the aluminum guard did not crack from the impact, it would have provided enough coverage to save the bumper and hood motion_photo_8928018439942892606.jpg
    Screenshot_2025-11-06-19-12-43-74_40deb401b9ffe8e1df2f1cc5ba480b12.jpg Screenshot_2025-11-06-19-12-58-10_40deb401b9ffe8e1df2f1cc5ba480b12.jpg
    aussiejosh Thanks this.
  3. DUNE-T
    7,054
    17,193
    May 10, 2015
    Detroit, MI
  4. tscottme
    tscottme Road Train Member
    There's no defense against the golden BB. I'd stay with the replacement of the original bumper, hood, deer guard. As they say in aviation, you can make the airplanes crash-proof but you can't be sure they will be able to fly if you do so.
  5. '88K100
    '88K100 Road Train Member
    1,493
    3,610
    Aug 23, 2020
    I know that in my area the moose guards reduce the damage by 75% or more
    The bigger guard you suggesting only has to hit one deer to pay for itself
    Deer have never done a thing more than bend my bumper. Moose tend to take chunks out of the hood and if you take one in the grill your rad meets fan and you’re getting towed
    1999 C12, Albertaflatbed and DUNE-T Thank this.
  6. Accidental Trucker
    Accidental Trucker Road Train Member
    3,439
    7,815
    Jun 4, 2015
    It's not the cost of the repair, it's the down time. We run the bigger guard after a few hits, and so far it's done it's job and scared off all the deer. Dang near clipped an elk in WY on Saturday night, fortunately the truck ahead of me sacrificed itself for us......
    Stories aside, more bars is better, but sometimes they will still hit just right to slip through and take out a headlight. They aren't a guarantee. but I'm running one anyway.
  7. Arctic_fox
    4,529
    25,629
    Sep 16, 2016
    Depends on the style of bumper, speed and where you hit. Imo though i had the big heavy steel herd guard on my old peice of shi....err on my pete. Took a deer at 73 and said deer just vaporized and very slightly bent the guard. The herd guards are just that much sturdier.
    Those tube guards like you have are alright but cant really stand up to a hit like a proper bumper and guard integrated set. They will prevent a lot of damage to stuff like radators and such usually....but as you found out, not much more.
    1999 C12 Thanks this.
  8. DUNE-T
    7,054
    17,193
    May 10, 2015
    Detroit, MI
    The herd guards are like 5k nowadays. I never drive in areas with moose and my old Volvo is front heavy, so I doubt I will be getting that one
  9. DUNE-T
    7,054
    17,193
    May 10, 2015
    Detroit, MI
    The ones from the pics are steel and should be way stronger than the aluminum one I had
  10. Arctic_fox
    4,529
    25,629
    Sep 16, 2016
    Fair, i dont know how much a volvo bumper is. I know on my pete it was almost $1800 and its nearly 3k on my lonestar so cost wise they are a wash when you add on the $1200 odd dollars for a larger tube guard. But they both have the factory steel bumper. So im unsure how that compares to a volvo.
    That said they arent as heavy as you think. The one on my pete was 500ish pounds and it was the heavy duty one. I think the standard aero is 350ish? And its almost as robust. Plus dont forget you can take the weight of the OEM bumper off that. I know on my lonestar the plastic one is 120 pounds with the clips mounts and such and the steel one is 280. Figure if your plastic one with clips is around 100. And the tube guard is around 100 as well. Its not a huge jump weight wise.
    They also have a lighter duty one that is aluminum and is technically more robust and cheaper, but cant be fixed easily if its cracked or bent and tends to oxidize pretty quick if you dont keep it clean and waxed.
    DUNE-T Thanks this.
  11. Moosetek13
    Moosetek13 Road Train Member
    14,988
    19,046
    Nov 1, 2010
    Burnsville, MN
    Never say that you hit a deer.
    Only say that the deer hit you.
