I have a 2011 Freightliner Cascadia with DD 13 I am trying to T/S a code 4364.18 .While running the Detroit troubleshooting program it tells me to disconnect the DEF doser valve electrical connector before running a Regen. I can not find the connector . Any of you Detroit or Freightliner guys know it's location ? Thanks in Advance .Any direction to go for the trouble code helpful too
DEF Doser Valve Electrical Connector Where Is It PLZ
Discussion in 'Freightliner Forum' started by habfleet, May 14, 2020.
its on the one box i believe
also check the def filter by the def tank.
A 2011 truck would be EPA10. DEF metering dosing valve is mounted on the back of the 1-box housing. TheDieseler on Youtube have a 3 minute video on the Metering unit. At 1:21 in the video it shows the connector to the valve.
habfleet Thanks this. -
If your truck has 600l plus miles don't spend your time to troubleshoot this code. 99% you will need new one box.habfleet Thanks this.
Ok Thanks 400000miles seems to be running OK know Thank You
