def hose
Discussion in 'Truck Stops' started by s0231198, Jul 11, 2016.
  1. s0231198
    s0231198 Light Load Member
    143
    245
    Aug 23, 2008
    Can anyone tell me how long the hose is to fill a def tank at the pilots? Have a fire truck with the def tank on passenger side and would rather not deal with 2.5 gallon jugs, it does have a walkway right behind cab that could stretch it across if long enough and tank is right at edge of walkway.
  3. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    Some of them are 8 to 10 foot long.
  4. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    They won't generally reach across and back to the filler. Even if they were long enough, you'd need 2 people to manage the hose extension process that wants to retract at all times. Many will buy at the adjacent pump to the right, then pump, as opposed to coming in "backwards"
    Friday and tucker Thank this.
  5. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    It will probably reach. most of them are so jammed up in the reel it's hard to get them out 3'.
  6. Friday
    Friday Road Train Member
    1,679
    2,011
    Apr 7, 2016
    Charlottesville, Va
    Do that one. It's next to impossible to get that hose to want to stay a couple feet out most times.
  7. Tai
    Tai Medium Load Member
    Its not common but I have seen some places that have def on both sides. Check to see if there one in the area? (Not luckily but always can hope.)
  8. s0231198
    143
    245
    Aug 23, 2008
    Found out it just reaches if park close enough to pump on drivers side, but nozzle is upside down when doing it!
    tucker Thanks this.
  9. Md420
    Md420 Medium Load Member
    469
    559
    Nov 2, 2015
    Tn
    that is the biggest pain. I drove a 2015 t680 with the def tank on the wrong side. Why in the hell would you do that
  10. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Kinda surprised at least some truck stops didn't put 1 pump with the def on the right side
  11. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Because who ever ordered the truck didn't know enough to make sure to order "DEF tank on the left side".
