DEF Light FLashing 10 Codes Paccar
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Proxy, Mar 20, 2019.
  1. Proxy
    Proxy Light Load Member
    165
    54
    Sep 3, 2018
    The truck has been perfect until today. Driver said the truck was low on DEF and went truck stop to add some and went into full derate the second he started it with no prior warnings. after starting the truck 10 Codes came on at once including flashing DEF light. Does it look like maybe it was completely ran out of DEF? I included a screenshot of the codes, what do you guys think?
    2016 T680 400k+
  3. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    The unit was not low on DEF. With an Emissions fault the DEF light on the gauge will come on or flash even with a full tank. Get in the shop to troubleshoot the SCR faults at hand.
    Suspect wiring issue or defective SCR temp / outlet NOx sensor.
    spsauerland Thanks this.
  4. Proxy
    165
    54
    Sep 3, 2018
    thanks for the reply! will post update after I get it in and checked out
    Goodysnap Thanks this.
  5. TruckerChance
    TruckerChance Bobtail Member
    20
    Nov 30, 2018
    Baltimore MD
    Any updates?
    I’m having the same issue with my 2013 t700
    Mx13
  6. Proxy
    165
    54
    Sep 3, 2018
    I responded other night from my phone not sure why it didn't stick stay...
    long story short, the driver definitely ran it out of DEF as he pulled into station to fill so it went into derate. Thing is it wouldn't come out after he filled the tank (despite what ive read) had it towed to the dealership they claimed there was a "loose wire" at a specific connector... coincidence? possibly but you know how those things go.... no issues since
    TruckerChance Thanks this.
