def problems
Discussion in 'Freightliner Forum' started by owens_10, Jan 28, 2020.
  1. owens_10
    owens_10 Bobtail Member
    I have a 2013 freightliner the driver is completing of a diesel smell in the cab I have looked it over and can see it is wet by the def doser tip before the dpf have changed the doser tips before the dpf system and after the dpf system anything will help was thanking of changing the dpf doser unit but dose not explain the diesel in the exhaust
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    Is it exhaust or actual fuel that the driver is smelling?
    All the fuel lines are on the driver side, cab air intake is on the passenger side..
    Did they step in a puddle of fuel in the fuel isle?
  4. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Two things I can think of that might be your problem.
    1. Look at the bellows tube and make sure there it isn’t leaking anywhere. I have seen them crack toward the center of the truck and it wasn’t easily identifiable.
    2 there maybe a chance there was some crud on the Farrell of the steel line at the doser injector the last time it was changed. Remove the line and check the seats for distortion’s that might not let it seal.
