Def tank removal
Discussion in 'Freightliner Forum' started by me myself and I, Feb 20, 2020.
  1. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    How difficult can that be? Ive got a coolant leak there that i can't pinpoint.
  3. Vegas unlimited
    Vegas unlimited Bobtail Member
    37
    43
    Feb 18, 2020
    Csscadia?
  4. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Usually a coolant leak there is the coolant control solenoid leaking. There is a o-ring kit for it. As for removal, it depends on how munch flailing you have in front of it. And how much crap you have on top of it. All the connections you have to undo are on top of the tank on the sending unit. And they will all have to be undone before you can slide the tank out away from the frame.
    Vegas unlimited Thanks this.
  5. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    A04-31573-000 is the Freightliner part# for oring kit.
    Working2party Thanks this.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    I currently have a coolant leak I thought was def related buts it turned out to be bunk heater core right above it..
    Vegas unlimited and Working2party Thank this.
  7. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Good catch. Easy to misdiagnose in that area.
    magoo68 and Vegas unlimited Thank this.
  8. Vegas unlimited
    37
    43
    Feb 18, 2020
    Its 120 dollars at dealer and @uncleal13 has posted thread how to replace it.
  9. me myself and I
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Ive got the kit. They've must had thought about me when they made it. Came with pics;). Too bad they didnt include info on disconnecting def lines.
  10. Vegas unlimited
    37
    43
    Feb 18, 2020
    You dont need to disconnect def lines for that kit instalattion
  11. me myself and I
    735
    312
    Oct 5, 2009
    vernon hills,Il
    I didnt have to remove tank to replace those o rings. Kinda wish i knew that before ive spend all that time trying to just that;).
