DEF
Discussion in 'Ask An Owner Operator' started by nunofreddy, Jul 12, 2018.
  1. nunofreddy
    nunofreddy Light Load Member
    157
    64
    Jun 3, 2014
    I bought my first def truck 3 weeks ago 2019 pete 389 Cummins x15 just curious if there's a difference in quality of def from the one in the fuel pump or the boxed blue beacon kind? Or is it all the same?
  3. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    Pump is cheaper. But boxed is far better quality. Most techs say boxed will get about twice the miles from a tank of boxed def.
    nunofreddy Thanks this.
  4. Dave_in_AZ
    428,337
    Never new there was a difference. I do know the pump averages $2.80 gallon.
    I average about 180 miles for a gallon. And that varies. But it averages out to 180.
    It takes about 1 actual minute to put 3 to 5 gallons in at the pump.
    The blue stuff in the box costs A LOT more.
    I'm not sure the value is there though, especially with the hassle, cause I see 1 out of 10000 guys using it.
    Nothereoften and nunofreddy Thank this.
  5. nunofreddy
    157
    64
    Jun 3, 2014
    So it last longer? Does the cheaper one at the pump do any damage to scr system? Cause at pump is 2.8 gallon box is 15 dollars for 2.5 gallons
  6. nunofreddy
    157
    64
    Jun 3, 2014
    8 gallons of def from the pump gets used on 130 gallons of diesel not too bad I avg 6 to 6.3 mpg
    Dave_in_AZ Thanks this.
  7. Oldironfan
    5,776
    5,544
    May 22, 2017
    If you buy boxed it will give your better fuel economy and you emissions system will last longer.
    csmith1281 and nunofreddy Thank this.
  8. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Pump def won't hurt you. The only benefit to buying it by the box is convenience. The quality of pump vs box is negligible.
  9. Long FLD
    Long FLD Road Train Member
    12,958
    54,391
    Mar 4, 2015
    I’ve never driven a big truck with a def system, but when I bought my Dodge at the end of 2016 all they told me was to make sure the nozzle was clean if I was getting def at the pump instead of the boxed.
  10. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    We buy it in bulk and fuel when at the terminal. Much cheaper.
  11. DYLAN_131
    DYLAN_131 Light Load Member
    136
    131
    Nov 21, 2018
    There is no difference in the quality of either. It's a regulated substance. 32.5% urea and 67.5% deionized water. I cant remember the ISO number. Pump def and box def are the same. Constantly proving the "DEF quality" wrong in the shop.
    I would encourage drivers who are getting a PM done to ask for a DEF test. As this will test the concentration of the two required substances. More specifically, if you're having DEF or DPF related issues, QUALITY of def is not the issue (again, it's a myth popularized by mis-information) but POSSIBLY condensation of water within the def tank.
    I say possibly because their are many devils within the DEF/DPF systems.
  12. DYLAN_131
    136
    131
    Nov 21, 2018
    These techs are just simply wrong. DEF consumption is based off of fuel usage, or "dosing rate". The accompanying equation does not account for pump or box def because their is no difference.
