DEF
Discussion in 'Ask An Owner Operator' started by nunofreddy, Jul 12, 2018.
Page 2 of 4
AModelCat, T.Rucker, MartinFromBC and 1 other person Thank this.
I've said this before and I'm sorry if its a broken record, but New Def, Good Def, Old Def... There is NEVER a good time for Def!! I'd rather be talked to like trash, spit on by 3 ###### at one time, run over by everybody in this forum than to EVER buy another truck with Def. Sorry guys im very bitter..
MartinFromBC Thanks this. -
I agree theres never a good time for def. As a mechanic I see bad things almost every day. However, a lot of the issues I've been seeing can be avoided by a small amount of driver maintenance. Granted, most of my work is done on PACCAR and a decent bit of Cummins.
I also fault some of my fellow mechanics for not trying to educate the willing...Nothereoften Thanks this. -
Educate me, what proper driver maintenance can I do?MartinFromBC Thanks this.
Aside from making sure you dont put diesel in the def tank or anything like that, it is mentioned in service manuals that it helps to never let the tank get below 25%. It helps to NOT idle the truck for extended periods of time. Do NOT add anything other than DEF into the DEF tank (I have seen people add various de-icing agents lately). When you get PM's done on your truck, ask for the differential pressure sensor to be cleaned (takes the mechanic 5 minutes if that). Do not pee, add water, or believe everything you hear in regards to DEF. Cummins offers drivers various educational brochures specifically on their aftertreatment systems. Explore and read OEM manuals and you will be able to avoid most issues. And dont, drive through the lights.
MartinFromBC and Nothereoften Thank this. -
Usually gets filled every third or fourth trip around 1/8 usually due to only one place on my run having it at the pump. Didn't know that it had a differential pressure sensor, I'll ask my mechanic next time to clean it. Where is it?MartinFromBC Thanks this.
How often does the filter need changed, really? And what about the def doser? Does the def system ever need to be flushed? Thinking about crystallization in the system.
Depending on the system, the differential pressure sensor is typically on top of the DPF filter canister (the large metal canister underneath passenger step on most semi's) some can be cleaned others just replaced.
Ok, my canister is behind the steps completely on an international. Actually looks like 2 mufflers side by side and I'd hate trying to take anything off the top but will look closer next time I grease itDYLAN_131 said: ↑Depending on the system, the differential pressure sensor is typically on top of the DPF filter canister (the large metal canister underneath passenger step on most semi's) some can be cleaned others just replaced.Click to expand...MartinFromBC Thanks this.
Page 2 of 4
Related Categories
Oil pan gasket
Spyro2112 posted Apr 22, 2026 at 12:38 PM -
Pending MC Application
Holland.david1970 posted Apr 22, 2026 at 10:14 AM -
Who to work with being new?
Gonzo1300 posted Apr 20, 2026 at 6:45 AM -
Lost detention pay again...
Michael23547 posted Apr 20, 2026 at 5:49 AM -
Load Profitablity estimate
RollinChaos posted Apr 18, 2026 at 8:35 AM -
OOs who does your taxes
77fib77 posted Apr 17, 2026 at 6:54 AM -
DOT Compliance
Autobahn66 posted Apr 16, 2026 -
O/O Only Companies
AppalachianDruid posted Apr 15, 2026 -
Renting a truck?
Holland.david1970 posted Apr 15, 2026 -
12.7L Detroit vs 14.0L Cummins...
Kruse Family Farms posted Apr 13, 2026
Loading...
Recent Threads
Reman vs New Content 3406e
2duisperyear posted Apr 23, 2026 at 10:05 AM -
Load securement pet Fmcsa...
mitmaks posted Apr 22, 2026 at 6:58 PM -
Gillco freightlines inc
ebsound84 posted Apr 22, 2026 at 6:43 PM -
Lawn Ornament
mjd4277 posted Apr 22, 2026 at 5:54 PM -
Tesla Driver Causes Wreck
mjd4277 posted Apr 22, 2026 at 5:53 PM -
Oil pan gasket
Canadian trucker goes airborne
JonJon78 posted Apr 22, 2026 at 12:16 PM -
CHP officer needs underwear cleanup
JonJon78 posted Apr 22, 2026 at 10:41 AM -
What to expect?
J.S. posted Apr 22, 2026 at 9:52 AM
Loading...
