Def
Discussion in 'Questions From New Drivers' started by Erjonb, May 9, 2021.
  1. Erjonb
    Erjonb Light Load Member
    56
    4
    Aug 27, 2019
    Hello, i need help. It shows that SCR System Fault Engine will Derate in < 60 mins.
    Def gauge isn't working at all.. what it might be?
  3. Arctic_fox
    4,808
    27,524
    Sep 16, 2016
    Need more info, what engine/truck/year/model? how many miles?
    That said considering my own trucks massive list of problems it could be #### near anything. Cheapest parts to rule out are the quality sensor, the doser and the NoX sensors. From there it gets...pricey.
    baha Thanks this.
  4. Erjonb
    56
    4
    Aug 27, 2019
    Oh yea my bad, its a volvo 2012 660k miles
  5. AModelCat
    166,505
    You said the gauge isn't reading, is the DEF tank actually empty?
    If the DEF tank module isn't reading properly on some trucks the gauge needle can point straight down or it'll have a light that will illuminate or flash.
  6. Arctic_fox
    4,808
    27,524
    Sep 16, 2016
    Likely a borked quality sensor and/or module in the tank. They seem to die around 55k or so in my experince. Try that first.
  7. Erjonb
    56
    4
    Aug 27, 2019
    No, it was half, and now its right below E. There's no other lights
  8. Erjonb
    56
    4
    Aug 27, 2019
    Do i have to go to the dealership for that?
  9. AModelCat
    166,505
    If it was at half and then suddenly dropped to Empty, I wonder if the sensor got hung up at half a tank, then freed up and dropped once the tank was nearing empty? Cheapest and quickest thing to try if that's the case would be to put a couple gallons of DEF in the tank and see if that does anything.
    gentleroger and SoulScream84 Thank this.
  10. Erjonb
    56
    4
    Aug 27, 2019
    Okay gonna try it once.. thank youb
  11. Erjonb
    56
    4
    Aug 27, 2019
    Still the same
