Def
Discussion in 'Questions From New Drivers' started by Erjonb, May 9, 2021.
  1. Cowboyrich
    Cowboyrich Road Train Member
    3,651
    35,246
    Dec 11, 2017
    Dayton, Washington
    My truck will do this occasionally, between about 3/4-1/2 tank of fuel then suddenly drops, atleast its manageable if you know what it is.
  3. Erjonb
    Erjonb Light Load Member
    56
    4
    Aug 27, 2019
    Yea but i have that text that engine will derate. And today is Sunday so nobody's working
  4. sevenmph
    sevenmph Road Train Member
    2,963
    15,198
    Jan 26, 2007
    Pinellas county Florida
    If it derates unplug the speedsensor from the transmission. Your speedo won't work but you will get where you're going.
  5. Erjonb
    56
    4
    Aug 27, 2019
    Im heading to Texas, so its better if i just stay where i am for tonight. Thanks for the suggestion tho
  6. SoulScream84
    3,609
    28,150
    Mar 21, 2020
    2012 it should be manual, but if it's an auto unplugging the speedsensor will keep the trans from shifting.
  7. Erjonb
    56
    4
    Aug 27, 2019
    Its an i shift
  8. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,985
    Nov 1, 2017
    The Sticks, Idaho
    Ive driven auto shift Volvos with the speed sensor unplugged... It will still shift, but it wont build any boost... So its gutless.
    SoulScream84 Thanks this.
  9. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Try disconnecting the batteries for a few minutes. I had a similar issue and this worked to reset the system and it let me travel a few hundred miles before it did it again.
    Odd thing was it ultimately appears to have been the wire going to the 7th injector (doser) was getting too hot. I noticed the wire lost it's insulation and had dropped down from its normal position along the valve cover and was laying on the side of head.
    Once I reinsulated and rerouted it to a cooler location the problem has not reoccurred.
    However, I don't recall that my DEF gauge was acting up.
  10. SoulScream84
    3,609
    28,150
    Mar 21, 2020
    I suppose it's a YMMV situation. Had a Mack with the M shift and it wouldn't go higher than 3rd with the sensor removed.
    Cattleman84 Thanks this.
  11. Truckermania
    Truckermania Road Train Member
    1,193
    1,814
    Oct 13, 2011
    Sturgis,SD
    Do a parked regen. Should take care of it.
