Def
Discussion in 'Questions From New Drivers' started by Erjonb, May 9, 2021.
  1. Erjonb
    Erjonb Light Load Member
    56
    4
    Aug 27, 2019
    I tried to see it, but can't figure it out where it is
  3. Erjonb
    56
    4
    Aug 27, 2019
    It doesn't go through. I tried
    Truckermania Thanks this.
  4. Truckermania
    Truckermania Road Train Member
    1,186
    1,807
    Oct 13, 2011
    Sturgis,SD
    In that case, probably the only solution is to take it to a Volvo mechanic. I did have a similar issue once and even had a tow truck lined up to get me in the morning as I was already stopped for the night. My truck would not do a forced regen but it was real cold that night so I idled all night. Well, the truck did a regen all by itself a couple times during the night and everything cleared up on the codes so I cancelled the tow truck and went on my Merry way. Hope you can get yours taken care of.
  5. Erjonb
    56
    4
    Aug 27, 2019
    So you suggesting to leave it on all night? Maybe it would fix the problem? Bc it says it will go in derate mode in less than 36 mins rn.
  6. AModelCat
    165,166
    DPF is a different system than the SCR. A regen would more than likely be a waste of time.
    Dockbumper Thanks this.
  7. Erjonb
    56
    4
    Aug 27, 2019
    It doesn't go through at all even if i want to do it. There's nothing i can do tonight, just to wait for tomorrow morning to go at dealer
  8. sevenmph
    sevenmph Road Train Member
    2,961
    15,063
    Jan 26, 2007
    Pinellas county Florida
    Yeah plus I see later you said it was an I shift so that won't work.
  9. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,863
    Apr 29, 2020
    I had a "poor quality def" " engine will derate" warning last week on a 2019 KW 680. I was about 2 hours South of Little Rock on I30. Made it to the KW dealership in LR without issue. Bad DEF sensor. Replaced sensor. No problems since.
    baha Thanks this.
  10. Truckermania
    1,186
    1,807
    Oct 13, 2011
    Sturgis,SD
    Yes that was what I was suggesting. Just because it is in derate mode does not mean the truck will not stay on. Just means you can't drive faster than 5 mph.
    Reason for edit: Correction
  11. Dockbumper
    3,778
    9,863
    Apr 29, 2020
    Not quite sure about that.....I could be wrong. It may just shut down in 32 minutes. Also, keeping it running won't solve your "DEF" issue. It is emissions related and EPA requirement on the manufacturer are very strict, (right or wrong), let's not start that debate in this thread. It may not start with a faulty DEF issue. Let us know the verdict.
