Deff pump problem on 2011 Volvo D13
Discussion in 'Volvo Forum' started by aunimni, Apr 15, 2021.
  1. aunimni
    aunimni Bobtail Member
    11
    4
    Apr 16, 2016
    Two days ago I got two codes on my Volvo.
    SPN 4376 FMI 5
    SPN 4376 FMI 7
    I used to hear deff pump running at least 20 seconds after I shut off tractor now it's only 3-5 seconds. Can anyone help me with this issue.
    Thanks in advance.
    Trucking Jobs in 30 seconds
  3. Rob100100
    Rob100100 Light Load Member
    183
    106
    Mar 5, 2016
    It might be your def return valve is stuck. Have to take it to a good shop. Your def system might not clean properly and derate you at some point. Called russian roulette if you ignore it for too long
    aunimni Thanks this.
  4. aunimni
    11
    4
    Apr 16, 2016
    Thanks. I will check ✔️
  5. Navreetgill
    Navreetgill Bobtail Member
    8
    Apr 29, 2021
    Systen delete
  6. aunimni
    11
    4
    Apr 16, 2016
    What is the meaning of that!?
  7. Truckwork2461
    Truckwork2461 Bobtail Member
    36
    11
    Feb 10, 2021
    Def harness has an open circuit/rubbed wire. Need to check the harness or replace the harness. You also need to check for leaks in the def system such as the def flex pipe. If those don’t correct the issue then you will need a def pump replacement.
  8. aunimni
    11
    4
    Apr 16, 2016
    I checked the wires and harness and pipes everything looks good. I ordered the deff pump so we'll see. Let you know guys here what happened after replacement.
    Truckwork2461 Thanks this.
  9. aunimni
    11
    4
    Apr 16, 2016
    Where is the location of def return valve??
  • Draft saved Draft deleted
