Definition of "No Modifications"
Discussion in 'TMC' started by K9OTR, Jan 16, 2014.
  1. K9OTR
    K9OTR Light Load Member
    146
    84
    Sep 1, 2013
    Rochester, NY
    I'm still weighing my options on places I'd like to call "Home", I've read in a number of older threads questions regarding inverters or other various items that NO MODIFICATIONS were allowed. I understand that inverters are now company provided and as such are a non issue. But other than inverters are there any other examples of Do's and Don't's with regard to this policy?
    For example, would a 12v cooler, Inverter fed Refrigerator be considered a modification, or perhaps a second (no-drill) mirror mounted antenna, GPS or other electronics. I'm generally a detail oriented person, and just curious as to if theres any further explanation of this policy.
    Thanks in advance,
    K9OTR
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Those are okay. They are speaking of physical changes like chicken lights or having someone changing the engine settings.
    All them little things you mention are common items that can be easily removed.
  4. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Ont he inside, anything that plugs into the cigarette lighter is aloud. No running your own wires. Things like a sat radio, gps etc are all fine. On the outside of the truck, feel free to mount an extra antenna, but remove it before going into service. they want all the trucks to look identical and a different antenna looks different.
    Inverter fridge is ok, but it cant be mounted or damage the interior. They go through the truck with a fin tooth comb and will find any mounting holes.
    Keep in mind, the inverter doesn't shut off untill 11 volts. On a cold day they may or may not be enough to start the truck. You only get one free jump start per year.
    K9OTR Thanks this.
  5. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Every driver should own their own jumper cables. Invest in a good 4 gauge 16'-20' set. You'll use them more than once in your career. If not your truck then for helping someone else.
  6. K9OTR
    146
    84
    Sep 1, 2013
    Rochester, NY
    I do own a pretty good set of cables my father made me, they're made with 0/0 welding cable, about 20ft long... only thing is that their heavy.
    Along those lines would it be prudent, to have one of those light weight portable, honda generators in a side box, for emergencies/extreme cold or is that just being paranoid and one extra thing to get in the way?
    http://powerequipment.honda.com/generators/models/eu2000i
  7. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    That's going above and beyond. Doesn't sound like a terrible idea, but it might be a bit overzealous. You also have to consider the additional weight and also that you'll have a lot of stuff to carry... tarps, chains, binders, dunnage, etc. I don't know how accommodating TMC trucks are in that regard, but you can fill your side boxes up quick, and really want to keep that space available.
    Before you go jump starting your truck off another truck or go jump starting someone else's truck, make sure you're shown how to properly do it.... again, I don't know the ins and outs of TMC's fleet, but you'll want to be aware of things such as frame mounted electronics and the like, because those could be blown if you don't do it right.
    K9OTR Thanks this.
  8. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I'D say "just being paranoid and one extra thing to get in the way?". first off the TMC petes dont have tons of storage space. Secondly anything fuel burning id not aloud in the cab. It would only be aloud to be out in the trailer. Thats one more thing to transfer on every drop and hook.
  9. K9OTR
    146
    84
    Sep 1, 2013
    Rochester, NY
    Thats very true, I wasn't even thinking about the fuel aspect!
  10. milskired
    milskired Road Train Member
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    Honestly, instead of running your own antenna run one of the ones on the truck. Mine worked very well I just put a new piece of good coax in and unhooked the 2 antenna into one thing and just ran the one with good coax. I also would run my own radio in my truck but it was a pain having to take it in and out every time I was at the terminal which was often since I would pick up at John Deere about 20 minutes from the terminal ALL THE TIME!!! You will be good with a GPS, Invertor, 12v fridge and an XM radio. I had my own small coffee pot in the truck that I ran off my invertor. Saved me lots of money! Just take the half and half creamers and sugar packets from the Pilot and they don't even need to be in the fridge!
  11. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    TMC doesnt allow you to use your own CB anyway
