Delphi radio issues
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Rooster1291979, Jun 14, 2018.
  1. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    I bought a new radio for the truck. It's the delphi bluetooth with sxm. I have it paired to my phone and it works well.
    However, when I turn off the truck and turn it back on it reverts the source back to weather at the same volume as I was using on bluetooth. Start the truck and it's just a wall of static 90% of the time.
    How do I keep it on bluetooth?
  3. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    Mine does that too. I also have the Delphi. I'm pretty sure that's normal.
  4. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    I doubt you could have an option to default to Bluetooth source. But have you ever used a source other than Bluetooth or Wx? Defaulting to Wx doesn't seem right unless that was the last tuner source used. Does it have a continuous power supplied where it should? Does the clock retain the correct time?
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    Get rid of that radio and put a Kenwood or pioneer in, Delphi just makes big money because they label themselves "semi radios" emphasis on semi, overpriced, 15 years behind the times on features.
  6. Ahunter
    Ahunter Bobtail Member
    I have a 2015 Peterbilt 579 Delphi radio , it will power on but after 5 seconds it will power itself off I bought another radio thinking it was the radio but the new one doing it to , can someone help me with this problem
  7. skallagrime
    3,855
    9,928
    Apr 10, 2012
    Indiana
    If a brand new radio is doing the same thing, you probably have a short or ground issue somewhere, can't help beyond that, if you can verify that mempower and key power are clean, it may be that your speaker wires are backfeeding into the power loop somewhere
  8. fpheavyhaul
    fpheavyhaul Bobtail Member
    5
    decatur,texas
    I have a issue with mine I can’t get it to go to channel 0 so guessin mines broke. It’s on a 2017 peterbilt 579
