Detention and TONU
Discussion in 'Freight Broker Forum' started by Dino soar, Jun 2, 2018.
  1. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I am wondering what the Brokers perspective is (and also o/o) on detention and TONU.
    From what I have read some owner operators do not put any detention time in their agreement and try to just get more money out of the load and if there is a problem they'll attempt to get detention. Then at least they got a higher rate for the load. I've read where some owner operators are reluctant to put that into the initial agreement. Do you prefer that owner operators put detention pay and TONU into the agreement?
    When you initially pick up a new customer, do you not discuss with them detention pay and TONU? If it has already been discussed, why isn't that just part of the regular agreement consistently?
    Is there a "going" rate for detention and TONU?
  3. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    I base detention off of what the truck normally makes per hour. Everyone will vary some.
    Oldironfan Thanks this.
  4. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,002
    Jan 9, 2012
    glasgow ky
  5. boredsocial
    boredsocial Road Train Member
    1,591
    2,493
    Apr 13, 2014
    Louisville, KY
    From a brokers perspective it depends entirely on the customer. From what I've seen across many accounts the people who should be paying detention don't pay it and those who probably shouldn't have to do pay detention.
    If you're doing a load of produce assume it will involve half a day of waiting on each end and won't pay detention. This doesn't mean 'don't haul produce' it means 'charge accordingly for the line haul'.
    wore out, KB3MMX and gokiddogo Thank this.
  6. TallJoe
    TallJoe Road Train Member
    7,490
    16,274
    Apr 12, 2016
    Chicagoland
    CHR and Coyote and perhaps some others are brokers who would predetermine a detention rate in advance, depending on a customer. For example, they will state in their rate con, the detention starts after 3 or 4 hours $25 do per hour max $220. It is often either you take it or not. I imagine this can be changed/renegotiated, if they are desperate but this tells you that you can't count on detention as a money maker. Such loads (to Walmarts, Krogers, Krafts and such) should pay much better in the very rate.
    DSK333 and KB3MMX Thank this.
  7. Dino soar
    4,815
    27,071
    Dec 8, 2017
    Thank you for the replies.
    When you initially make contact with a new broker do you put detention in the agreement?
    And do Brokers pick up new clients without ever discussing detention or TONU?
  8. DSK333
    DSK333 Road Train Member
    2,413
    2,756
    Jan 27, 2018
    Pennsyltucky
    CHR and Coyote apparently enjoy insulting carriers with that disgusting "take it or leave it" lowball mentality. I wonder how many times their freight gets put in storage. No way I would sit for 4 hours for free.
  9. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    Coyote: pulled 1 load, took 4 weeks to get paid while on "quick pay" setup. Now they call, I give them outrageous quotes, and they balk (good riddance)
    CHR: I get $100-200 more via "my special agent" versus the posting agent. I also get $50-75/hr detention, but 90% of the time, I get unloaded early or within 2 hrs. Being on paper-logs helps keep that on-time delivery to 100% all the time.
    shogun and DSK333 Thank this.
  10. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    I still can't bring myself to sign addendum D or whatever on Coyote's setup packet- the one that says I agree to run for $1.10 a mile.
