Detroit 12.7 2006 issues
Discussion in 'Freightliner Forum' started by Sega2010, Apr 2, 2014.
  1. Sega2010
    Sega2010 Bobtail Member
    25
    14
    Aug 8, 2012
    Just had new turbo and one injector put in my 2006 detroit 12.7 to a problem I had. Iran is three days after I got this fixed and the problem has come back. Check engine light comes on and the truck runs really rough like it's missing . Seems to only do this at the start of my day when it's cold out . The check engine light comes on for about 10 seconds then goes off and comes back on. When it was first doing this the clothes showed 2 bad injectors but we only replace one because when we hook the computer back up to it later on a only show one bad injector so I have to three days of running yet I am having the same symptoms after three days of running it since I put new turbo and injector
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    by your description it sounds like your problem from the start is the injector harness,not injectors.you might want to try a different shop.throwing parts blindly at a problem is very expensive( $2000 turbo/$500 per injector)good luck.
  4. Sega2010
    25
    14
    Aug 8, 2012
    Yaa that's exactly what I spent plus labor and it fixed problem for 3 days somehow now back at it I'm still running truck until it gets real bad cause I need to make money hope I do t make it wirse
  5. RSQ20
    RSQ20 Medium Load Member
    Why dont you do a balance test and see if an injector is not firing?? Then you can test the harness to see if the signal is getting to the injector.
    .... Philip
  6. Sega2010
    25
    14
    Aug 8, 2012
    Hooked it up to computer says injector 1 not responding but we ran the test on computer and it passed I hope if I buy another injector it fix my problem
