Detroit 60 12.7air conditioner
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kchav89, Aug 21, 2023.
  1. Kchav89
    Kchav89 Bobtail Member
    5
    So my a/c cools great at a low rpm or idle and blows strong as it should but when I accelerate it still blows cool for the most part but it loses its blowing strength it's like I turned it down from 4 to the 2 setting, what could it be and where exactly do I need to look to possibly fix the problem. I know on a regular car or truck the vacuum check valve could be bad but I've looked for the diagram and I have no idea where that would be or what to even look for, any help would be greatly appreciated.
  3. AModelCat
    166,497
    Shouldn't be anything vacuum operated, diesel engines don't generate vacuum because they don't use a carb or throttle body to control inlet air.
    Opendeckin and singlescrewshaker Thank this.
  4. AModelCat
    166,497
    What truck are we dealing with? Series 60 was available in pretty much every truck brand at some point.
    singlescrewshaker Thanks this.
  5. Kchav89
    5
    Well that makes sense, now that I think about it I'm no mechanic, any idea why the rpm's being higher driving down the road would make it do that?
  6. Kchav89
    5
    2020 Coronado
  7. Jesh574
    Jesh574 Bobtail Member
    8
    6
    Jul 26, 2023
    Alaska
    When the blower strength drops off do you notice your battery voltage dropping at all, dashs light going dim etc... or if you can hear the blower motor under normal driving conditions, does it change pitch at all? sounds like the fan slows down or no change at all?
  8. Kchav89
    5
    Just sounds like something's closing off
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,590
    6,684
    Aug 26, 2014
    Is it possibly related to road speed more than RPM?
  10. Rideandrepair
    17,601
    56,990
    Aug 8, 2015
