Detroit 60 Series HELP 14L…
Discussion in 'Ask An Owner Operator' started by GreenTop60, Apr 30, 2022.
  1. GreenTop60
    GreenTop60 Bobtail Member
    16
    Apr 30, 2022
    How do y’all suggest I get the most mileage out of my truck? I have some blow by and it worries me but it’s been their way for the last 100k miles. People I speak to at truck stops and what not say that it’s normal it don’t want to be on the side of the road. I’ve got about 965k on the dash and I want to get to the 1.2 to 1.4 million mile range I hear other people say it can get to. My motor has outlasted my transmission, clutch, eco, vpod, turbo, and egr so I know it’s got more life in it. Thanks!
  3. merv85
    merv85 Light Load Member
    151
    342
    Mar 24, 2020
    Dallas, Tx
    show it to a proper Detroit mechanic, if inframe is needed than get the inframe done
    what year is your detroit?
    GreenTop60 Thanks this.
  4. GreenTop60
    16
    Apr 30, 2022
    2006 still running strong
  5. nikmirbre
    nikmirbre Road Train Member
    5,649
    10,500
    Jul 27, 2011
    High Point NC
    I had a 2006 14L that I sold at 1.1 million miles I bought at around 450k miles. It had blow-by from day 1. It was always a little worse when it came oil change time. Blow-by is normal....
    Ive got a 12.7 now that has 500k on it now, I bought it about 3 years ago with 365k. It has had blow by since day 1
    Ive always had 12.7's and have always had blow by!!
    rollin coal and GreenTop60 Thank this.
  6. RubyEagle
    RubyEagle Medium Load Member
    632
    790
    Apr 17, 2010
    Yep they do it. Any recent oil samples?
  7. GreenTop60
    16
    Apr 30, 2022
    That’s what everyone says, I should probably stop worrying about it so much
  8. GreenTop60
    16
    Apr 30, 2022
    No but I think I should start doing it. Every pm? What would I expect it to tell me?
  9. pavrom
    pavrom Road Train Member
    3,258
    7,592
    Apr 29, 2012
    NE illinois
    You expect to find out when your overhaul is coming :)
  10. RubyEagle
    632
    790
    Apr 17, 2010
    Yeah every PM. it will show how your oil is holding up viscosity wise and any excess wear metals or fluids. Excess fuel would be fuel dilution meaning you may have leaking injectors. Sodium and potassium could be coolant from the EGR Cooler leaking, excess lead is bearings wearing, etc. It truly is great information for only $35 or so. I use Blackstone Labs, they send free sample bottles.
  11. bad-luck
    bad-luck Road Train Member
    3,509
    6,506
    Nov 16, 2013
    Baltimore, Maryland
    I would do an oil sample at your next oil change. Its not difficult to drop the pan and have your mechanic check one of the bearings. But for a piece of mind if it were me I would have the rods and mains done. What you don't Want to do is spin a bearing. All engines have some blow by. How much oil is your engine using between oil changes?
