Detroit 60 series
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Yamada, May 16, 2023.
  1. Yamada
    Yamada Bobtail Member
    25
    8
    May 16, 2023
    What's the normal temp for the fan to kick on? Every time I start and turn off my truck my thermostat gives me different numbers from 150 200 170 what could be the problem?
    And when the FAM comes on it sits on 200 the rpm is set on 10,000 at idle
    Fan*
  3. Big Road Skateboard
    7,202
    40,929
    May 2, 2021
  4. Yamada
    25
    8
    May 16, 2023
    Is it normal for the temp to sit on 200 or should it be lower and what about the thermostat having different numbers every time started up
    I did some research and found it could be the oil temperature sensor
    Rideandrepair Thanks this.
  5. Big Road Skateboard
    7,202
    40,929
    May 2, 2021
    I'd say normal, especially summertime.
    Fan enaged should drop lower. Need to verify gauge accuracy before going any further.
    Rideandrepair, beastr123 and Oxbow Thank this.
  6. Yamada
    25
    8
    May 16, 2023
    I replaced the water temperature sensor but the fan never kicks on, I checked the connections and wires forgot to mention I have fault code:
    PID-110 FMI 3
  7. Big Road Skateboard
    7,202
    40,929
    May 2, 2021
    Is the code active? Do you have a check engine light on? If you turned the key on while the coolant temp sensor was unplugged, you'd get this fault.
    Where are you running, and how heavy? If your coolant temp doesn't get up to temp, your fan will never come on
    Yamada, Bean Jr. and Rideandrepair Thank this.
  8. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    Flat land no wind, hot summer day, truck stays around 180.
    Takes a long hill, warm air, heavy load, and the fan doesn’t turn on until like 215. Way too hot for my liking. I always manually turn the fan on around 200-205
    Yamada and Rideandrepair Thank this.
  9. Trcknwolf
    Trcknwolf Light Load Member
    57
    27
    Nov 24, 2010
    Bellevue, NE
    The engine fan turn-on temperature setting is a fixed value within the Detroit DDEC ECM programming. Your thermostats do have some control on this as there are thermostats that open/close at different coolant temps. My 1999 Pete (factory 500hp series 60 engine) has always had 195 degree stats. My engine fan comes on around 210-215 degrees per the coolant temp gauge needle. Is it exactly accurate? Probably not. So, all is normal. An older diesel engine block making some heat just adds to the seasoning! LOL
    JoeyJunk, Yamada and Rideandrepair Thank this.
  10. Magoo1968
    Magoo1968 Road Train Member
    2,062
    5,493
    Mar 18, 2021
    St Malo mb
    At 10,000 rpm I’d expect it to be melting down at 1000 rpm 200 is normal.. as far as temperature jumping around I’d suspect a faulty temp sensor..
  11. Yamada
    25
    8
    May 16, 2023
    210-215? that's normal for you? I have the same exact engine
