detroit 60 start requirements
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Trugo, Nov 20, 2018.
  1. Trugo
    Trugo Light Load Member
    71
    50
    Dec 8, 2015
    I have a new to me 1995 freightliner FLD with a 11.1L detroit 60.
    I had it running and it seemed to be running ok, the cruise doesnt work but otherwise it ran. Then it shut off suddenly and I cant get it started again. The starter works fine, it cranks but wont run, unless I spray start fluid.
    The fuel filters are full and there is fuel in the tanks. The truck itself needs to be re wired. The dash lights are doing funny things as well as the ignition switch. I dont see a check engine lighting up, however its hard to tell on this truck which dash light does what. Besides that the dash lights are behaving erratic.
    I want to isolate the engine and run it directly off the batteries and then rewire from there. Can anyone tell me what this engine needs to run.
    So far Im thinking:
    -Air
    -Fuel pressure (what is the correct fuel pressure?)
    -Power, ground, and switched power to ecm (any others?)
    -Engine grounded to chassis (location?)
    Is there anything else? Info is appreciated.
    Rideandrepair Thanks this.
  3. Eagertruckers
    Eagertruckers Bobtail Member
    Nov 20, 2018
    Buddy
    Do you have a mechanic? Perhaps mobile
  4. Trugo
    71
    50
    Dec 8, 2015
    yes, the mechanic is me. Hes most affordable.
    stoan, Rideandrepair and swaan Thank this.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Go to the batt box and find the 2 small wires conn. to pos and neg. batt posts they lead to your ECM, clean both of them and ck the fuse inside the plastic box on the pos. wire, then try to start it
  6. Rideandrepair
    17,561
    56,896
    Aug 8, 2015
    Worked for me 2 days ago also check ecm fuse at battery connection. Will cause the condition also
    Working2party and baha Thank this.
  7. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Make sure the fuse is tight and not corroded also, I’ve seen them loosen and drop power intermittently.
    When you turn the key on both the red and yellow engine lights should come on for a few seconds if the ECM is powered.
    If you pull the power connector from the ecm you can test that circuit wit a light bulb. (Headlight if available. If that doesn’t work, follow the wires from the battery to the ecm, pull that group of wires down and remove them from the loom, look for any knicks, swells, crimp connectors, anything that’s not a good clean repair, etc.
    On that old of truck, any knick in the insulation could have corroded, or burn the wires. Any repairs to those wires should be repaired with soldered and heat shrink (good shrink with glue)
    If you’ve followed them all the way to the ECM, and all is well, you should be able to find the ignition wire from the cab to the ecm. Should be a one of the other wires coming from the same ecm connector. Run a jumper to the battery and the truck should start if it’s a cab wiring issue. I’d be guessing if I tried to help with any wiring to the cab.
    Rideandrepair and Trugo Thank this.
  8. Trugo
    71
    50
    Dec 8, 2015
    thanks all for the great advice. I did look at the battery box wires and the fuse in the battery box. The fuse is intact and the wiring looks ok, although that doesnt guarantee they are good. After taking apart some of the dash I found some green looking wires especially on the ignition switch. Also, the light indicator bar with the cel, stop engine light turn signals etc is completely melted and useless. Its hard to say what further damage is done in there. Whats for sure is the dash wiring needs repair.
    Im going to follow working2party's advice and check the ecm connector and manually wire the ignition wire as well as the cel and stop el for information purposes. Updates to follow.
    Rideandrepair and Working2party Thank this.
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Also requires correct input from two timing sensors.
  10. Working2party
    608
    729
    Feb 10, 2018
    Kansas
    The green around the ignition I’m assuming is corrosion. If that’s the case you need to remove all of it. If your looking for your repair to last.... As you strip the wires back, keep going until you have good clean copper. Solder everything. The cheaper heat shrink will do fine inside the cab, but make sure anything in the elements has a glue to seal them. With electricity, air is bad, moisture is worse, and any corrosion or loose connections make heat, heat drops voltage, and low voltage will burn up any electrical component. Looking into my crystal ball ( don’t get excited it’s only right about 10% of the time). A previous owner may not have known how to roll up a window, rain got the ignition switch wet, it corroded, gave low voltage to the light bar burned it up, and probably burnt up the ignition wire to the engine ECM. You maybe better off to search this sight, find a thread where someone has identified the pins for the power side of your DDEC 1,2,3 connector. Find the ignition pin, splice in and make the engine run before you get to into rebuilding the dash.
    As I think about it, I think the cab power is taken off the lug of the starter, you could have a problem there???
    Also, There May be a chance you can find the ignition out wire in the fuse panel and jump it from a power source there. there is supposed to be a curcuit diagram on the back of the cover/panel. Maybe an option that would cause less cutting and repairing wires.
  11. Rideandrepair
    17,561
    56,896
    Aug 8, 2015
    Also check Starter relay/ junction block on firewall above steering shaft and below wiper motor wires prone to break
    Trugo Thanks this.
