Detroit 8v149
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jan 23, 2024.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,416
    1,739
    Dec 4, 2019
    Were 8v149’s ever put in a truck? I see that they’re about 600hp. I know alot of folks are familiar with the 71 and 92 series but the 149 series is significantly larger. Were they just gensets?
  3. SmallPackage
    5,786
    18,578
    Dec 20, 2019
    Marion Texas
    I never seen anything in my research over the years that they were ever put in a truck. The 12v71 was big and barely fit in most trucks. The 8v149 dwarfs those. I know in the 1970’s lots of the drilling rigs down here in Tejas had them. They had a great sound. I remember spending many summer vacations on a location with my dad and get woken in the middle of the night when they’d start pulling a trip. Unmuffled days back then and them things would scream and shake the ground.
    bzinger, Crude Truckin' and JoeyJunk Thank this.
  4. mile marker 27
    1,416
    1,739
    Dec 4, 2019
    The cubes of an 8v149(1,192?) are somewhat close to 3408?
    Oxbow Thanks this.
  5. 201
    201 Road Train Member
    12,785
    26,306
    Apr 16, 2014
    high plains colorado
    Never heard of the 149 series. I knew you could get some pretty mombo Detroits. I read, mostly mining and marine use. I imagine they fall in the same category as those 800 hp CAT tugboat motors that all the pullers use. I imagine you'd still have to slam your finger in the door to get in the right frame of mind.
    mile marker 27 Thanks this.
  6. mile marker 27
    1,416
    1,739
    Dec 4, 2019
    It’s 94 cubic inches bigger than a 3408 cat but it’s probably wider because bore is much bigger.
    The Detroit has a square bore of 5.75”x 5.75”.
    Oxbow Thanks this.
  7. SmallPackage
    5,786
    18,578
    Dec 20, 2019
    Marion Texas
    3408 dimensions=
    Cid=1099.6 round up to 1100
    L=62.3”
    W=43.64”
    H=53.72
    8v149
    Cid=1192
    L=63”
    W=63”
    H=67”
    8v149 is a square bore engine so length and width are kept the same but they are still why to wide and tall to fit in an on the road truck even tho length wise they would.
    mile marker 27 and Oxbow Thank this.
  8. SmallPackage
    5,786
    18,578
    Dec 20, 2019
    Marion Texas
    They still rev to the stratosphere like the 71’s but with the torque they put out it would be fun in a truck. They were oilfield work horses at any rate.
    201 Thanks this.
  9. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    The 3408 that was built for trucks the block had a 75 degree Vee the equipment engine had a 90 degree Vee. They accomplished that by having the connecting rod journals offset 15 degrees.
    mile marker 27 and SmallPackage Thank this.
  10. 50WT
    50WT Road Train Member
    2,994
    27,477
    Dec 26, 2015
    Would probably need twin steer for that
