Detroit boost issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by periodic, Jul 13, 2021.
  1. periodic
    periodic Bobtail Member
    27
    14
    Aug 5, 2020
    2007 Freightliner coronado, 12.7 5915 injectors(new), 550hp tune, 169011 turbo (borg). 3.42 gears. DDEC IV.
    Getting 5.3mpg hauling lighter loads (30k max), barely any power pulling up hills. My electrical boost gauge on the truck is showing 17 PSI MAX, same as when I hook it up to the computer(ecm). Installed a mechanical gauge on it and it’s getting 27 PSI on that gauge.
    New boost sensor on it as well.
    Any advice on what it could be?
    truckdriver31 and jamespmack Thank this.
  3. jamespmack
    172,737
    Still need to pressure test system. 550hp? Should be about 35psi. Your low for a 470.
    You might have multiple issues. When and who did a overhead reset last?
    truckdriver31 Thanks this.
  4. periodic
    27
    14
    Aug 5, 2020
    when I did my injectors two weeks ago. Tanner diesel. Problem was there before the overhead and injectors.
    my mechanical gauge is reading out 27 PSI. Just the ECM is not getting a correct reading.
    jamespmack and truckdriver31 Thank this.
  5. truckdriver31
    6,350
    7,340
    Sep 18, 2013
    have you checked the air to air boots or the charger it self for leaks.
  6. periodic
    27
    14
    Aug 5, 2020
    It’s not leaking. My mechanical gauge shows the correct PSI.
    jamespmack Thanks this.
  7. jamespmack
    172,737
    Here we go, The whole story slips out slowly.
    Has anyone thought to out it on the dyno?
    Your correct psi is low still. Check fuel psi. How fresh is the
    Air filters and fuel filters?
    spsauerland and nikmirbre Thank this.
  8. little cat 500
    1,646
    728
    Jan 17, 2010
    Abbottstown PA
    boost leak ata more than likely junk
    Roger McG and truckdriver31 Thank this.
  9. truckdriver31
    6,350
    7,340
    Sep 18, 2013
    i thank so too. but he said no leaks
  10. little cat 500
    1,646
    728
    Jan 17, 2010
    Abbottstown PA
    If you read how he tested it its going to read the same ata is more than likely junk
  11. periodic
    27
    14
    Aug 5, 2020
    I’ve done the boost leak test. It stayed at 30 PSI for 5 minutes. There’s no leaks.
  • Draft saved Draft deleted
