Detroit DD15: overhaul or engine replacement
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bean87, Jul 7, 2017.
  1. Bean87
    Bean87 Bobtail Member
    Oct 26, 2012
    Hello! I've been browsing around for similar thread but couldn't find info about DD15. Got 2013 Cascadia with a Detroit DD15 in it with around 600000 mi on it. Yesterday this engine died on me, needs an overhaul. Freightliner mechanics say it will cost me around $28-30k for complete overhaul. There's also another option - I know a person who's selling DD15 with 350k miles on it for around $15k. I'm thinking about installing either this one or I found couple on ebay for 18-20k. There's also a local shop who claims to do a complete overhaul for around 15-16k, but I doubt their qualification and knowledge base regarding DD15. What would be the wise option to choose? Thanks
  3. Animosus
    Animosus Heavy Load Member
    732
    2,906
    Dec 7, 2015
    SE Wyoming
    28-30k. Sounds like it scored a cylinder and probably needs a crankshaft also?
    armo, Intothesunset and Bean87 Thank this.
  4. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    What's included in those estimates?
    The 28-30 through Freightliner seems reasonable and should come with warranty and use original parts.
    If you buy used in the 15-20 thousand ballpark, you have to consider xxxx amount on labour and no warranty.
  5. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Heck for 28-30k you could buy two more of those Cascadia's.
    NWAF, Kenworth6969, ODR and 14 others Thank this.
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You should look at buying a diff. truck unless you owe more than the truck is worth then tow it to the other shop and patch it up to sell it, then buy a truck that is ck out?P/S call the Det. shop and have them give you a est. it will be diff.
  7. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    These Post-Emission Trucks are just throw-away Trucks.
    Run them until they fail and junk them, they're not worth repairing unless it's Old Iron.
    600k miles and needs a Overhaul already?
    There's Pre-Emission Trucks out there that have over 1 Million+ miles without a Overhaul and still going strong.
    Fix it, Sell it or junk it and buy a Glider or Pre-Emission Truck.
  8. slickWillie1980
    slickWillie1980 Medium Load Member
    420
    35,545
    Sep 2, 2015
    Mt Olive, NC
    Man I can buy 3 BC 400 Cummins for that price lol. Still on the crate
  9. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    If you are going to rebuild it. Go to a Detroit shop not the freightliner dealership. And find out why it went down so fast should have gone at a million or more miles
    jason6541, CaptainDaveG and Bean87 Thank this.
  10. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    Personally, I'd go with the Indy shop or use that 28-30k to just buy another truck.
    Bean87 Thanks this.
  11. Bean87
    Oct 26, 2012
    Thanks for your replies. I found out that my truck has deleted DPF so my chances to repair it at authorized dealer are practically zero. Freightliner said they can restore DPF system + overhaul === $55-60k. So i'm going with indy shop. Another problem is to find parts for the engine. Detroit dealer said it will take up to 21 days to receive everything(except head), 7800$ for parts without head(hopefully mine is fine, need to test it tho) Wondering why there are so many problems with those D15s. Freightliner says parts are expensive and rare coz DD15 are generally considered reliable and can easily make 1 mil miles with no major problems.
    Also I believe that my engine died so fast because of deleted DPF.
    baha Thanks this.
