Detroit Deisel 60 Series
Discussion in 'Trucks [ Eighteen Wheelers ]' started by K108Aerodyne, Apr 25, 2012.
  1. K108Aerodyne
    K108Aerodyne Bobtail Member
    8
    New Plymouth, New Zealand
    I have a fault code when dianostic switch is pressed, it comes up with 3 red flashes, followed by 3 yellow flashes. from what i understand this would be fault code 33, which in book says it's a turbo sensor problem, but workshop tells me this is a no faults code, can someone tell me which is true?
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Kinda, when you initiate the flash code sequence the red lights indicate an active code, and yellow indicates an inactive code. In your case, you should have gotten one code from the red and one from the yellow. Watch it again and see if there is any pauses in between any of the red and yellow flashes, you should have gotten two different codes there, not one. There is a 1/2 second pause in between code digits, it is easy to miss.
  4. K108Aerodyne
    8
    ok will have to watch it again tomorrow, are the flash codes the same for each detroit series 60, mine is an DDEC VI EGR.
  5. Heavyd
    7,826
    6,276
    Feb 4, 2009
    That I don't know, we aren't a dealer for that engine anymore.
  6. Hammer166
    7,605
    27,793
    Aug 18, 2007
    ~8600+' and loving it!
    Got the same engine, and book is always close at hand. Red flashes the active codes, yellow is inactive. Code 25 is the no codes flash.
    Let me know I'll gladly look codes up.
