Detroit Diesel engine brake settings
Discussion in 'Freightliner Forum' started by istumped, Apr 20, 2015.
  1. istumped
    istumped Medium Load Member
    504
    241
    Feb 8, 2015
    Are they as programable as the cat engine? Sure would like to program it to how the cats operate. Thanks
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Cat's can be set up different ways, so saying that you want it to operate like a Cat is meaningless. How exactly do you want it to work? Yes, Detroit's can be set up in different ways too. Also both Detroit and Freightliner have been around a while, I'm not going to guess at what you have.
    Call a dealer with your VIN and ask them if it can be programmed the way you want it to work.
  4. Jetsr6
    Jetsr6 Light Load Member
    131
    46
    May 20, 2011
    Mechanicsville, VA
    Or get a custom ecm program from a performance shop.
  5. istumped
    504
    241
    Feb 8, 2015
    cruise on not set. Jake on. Jake will activate when bake is applied or cruise is turned off. I want to be able to shift with Jake on and not going off. This sure beets turning on/off all the time especially in traffic.
  6. istumped
    504
    241
    Feb 8, 2015
    Had the injectors tweaked made a huge difference.
