Detroit Series 60 14L Changing Fuel Pump - Prime It Y/N?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rbrauns, Apr 18, 2020.
  1. rbrauns
    rbrauns Light Load Member
    164
    56
    Dec 7, 2014
    Quick question. I have a 2008 Cascadia with a Detroit Series 60 14L. I need to change the fuel temperature sensor on the bottom of the fuel pump.
    Do I need to prime the fuel system with compressed air after unbolting it from the air compressor?
    truckdriver31 Thanks this.
  3. truckdriver31
    7,001
    8,366
    Sep 18, 2013
    it should have a hand pump too
  4. Rideandrepair
    17,607
    57,001
    Aug 8, 2015
    I don’t know for sure, but don’t think so. Might have to prime it afterwards to get it started. Pretty sure, from what I’ve heard that’s the purpose of the fitting.I think it’s for when you lose fuel in the head when changing an injector or line/ check valve. I would think filling filters would be enough to get it started afterwards. If not the air fitting is there, or a rag, and a blow gun, blowing it into the fuel tank will work.
  5. rbrauns
    164
    56
    Dec 7, 2014
    @truckdriver31, I have a Series 60 in my Cascadia and I don't see a hand pump anywhere.
  6. Rideandrepair
    17,607
    57,001
    Aug 8, 2015
    No hand pump, only an air fitting for priming system
    PE_T and truckdriver31 Thank this.
  7. QUALITYTRUCK
    1,821
    1,789
    Jun 14, 2009
    romulus,mi
    You wont have to prime it. Very little if any fuel escapes from sensor port.
    swaan, PE_T and Rideandrepair Thank this.
